20 Most Recent
JVC KD-G340 Car CD/ MP3 Player Questions & Answers
No sound from deck
Are the speakers connected directly to the JVC? If so, all four speakers going quiet could be bad soldering on the radio. If the speakers are not connected to the radio, then check the blue/white wire that turns on the internal amplifier.
Disc wont load.,
try buy a cd lens cleaner and if that dont work take it a part and take a qtip with rubbing achool and wipe the laser lens with that qtip and let it dry and then do it 1 more time and then let it dry agian and then put the cd back in and try to play it
Replaced the battery
It might be a good idea to check all of the fuses in the car. The radio requires two power sources in order to work properly.
I am trying to connect my JVC KD-G340 car CD
your ac-dc converter is not properly shielded or grounded, you need to replace it with a good one.(or you may wire you cd player chassis to a grounding receptacle, most ac outlets the center plugs are the ground terminals)
some car cd-player has a memory circuit, that will remembers on what state it was before power was remove, like yours it will play again as soon power is applied to it..
I have jvc car audio model # kd-g335 how to
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then:
If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier.
Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off)
Hope this helps.
dreamsystems
