20 Most Recent Pyle PLTS76U Car DVD Player Questions & Answers
0answers
Wiring
Be the first to answer 7/6/2013 3:46:54 AM • Pyle PLTS76U Car... • Posted on Jul 06, 2013Be the first to answer
3answers
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
12/30/2012 4:01:18 AM • Pyle PLTS76U Car... • Answered on Dec 30, 2012
CONNECTING AN AMP
Amp is powered by a main power wire to the battery, ground to metal chassis, and a remote wire (usually blue) from the D player to the remote in on amp. RCA's from CD player to amp as well. Not sure what you mean by "no amp wire on harness". Let me know so I can give you a more definitive answer.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
8/24/2010 6:27:45 PM • Pyle PLTS76U Car... • Answered on Aug 24, 2010
2answers
Wont play while im driving
hi, the problem with these dvd players is they have a safety feature that is connected to the parking brake and this means once the parking brake is taken off the dvd player then will stop.
PLEASE READ THIS.
you do this at your own risk keep reading and ill tell you how to best go about doing what you want, if you get caught using dvd whilst driving you will get a big fine and points on your license ok
Its not advised you use the dvd player whilst driving so i cant reccomend you doing any work to it yourself.
If say you wanted it working whilst driving so that a passenger could watch it then their is a way around getting this working whilst driving, if you get caught using this whilst driving you will get a fine and possible points on your license as your not supposed to have any working dvd in the front of the car whilst moving as you will get distracted.
Now the problem you have of getting this working whilst driving is that your going to need to get hold of the instructions that was used to fit the stereo as this will then tell you witch wire is connected to the parking brake once you have this you then need to bypass this wire by either earthing it out if its an earth wire or if its a possitive wire then you would need to wire this into a permanent live feed like the direct live feed into the stereo.
Now you could take the stereo out and see where all the wires go to doing this would then show you witch wire goes to the parking brake you would then need to test this wire to find out if its an earth or live type of wire, to do this you would need to get hold of a multimeter one of these will tell you if its a live or not.
If you find the wire thats connected to the parking brake you should be able to tell if its live or earth by looking at how its connected to the parking brake if its just earthed out then it will be an earth but if it goes to a switch on the parking brake then its more than likely a live wire.
On asking someone about your make and model of stereo it seems the parking brake wire is a brown wire and you then need to remove this wire from the parking brake and just earth it out on any part of the metal of your car this should then let you watch dvd whilst driving.
remember you do this at your own risk its not advisable to use a dvd whilst driving and you are breaking the law by doing this so i cant encourage you to go ahead with this type of work, if you really want to do this then take your time and double check you have the wires correct ok
its not worth taking the risk by just guessing as this could blow your stereo up leaving it scrap so its best this wire is tested.
If you are unsure what you are doing then please dont mess with it as any short will destroy the stereo and it has been known to cause several car fires so if it is a live make sure you use an in line fuse.
It would be a lot safer if you went to the makers web site and see if they have an instruction manual on their if they havent then they will send you one out for free this would be the best option for you.
If you really are unsure and have never wires stereos in before then leave it to someone who knows what their doing they may question why you want it working whilst driving but just tell them you drive a kid around who watches it to stop him being car sick, the sob story usually works
Let me know how you get on or if you need further assistance
5/27/2010 4:38:16 PM • Pyle PLTS76U Car... • Answered on May 27, 2010
I could be sitting right in my driveway and i put
The reason why is because the receiver is not registering that you have a constant ground connected to the parking brake. Depending on the model, you should be able to hook the wire that tells you parking brake up to the ground wire of the receiver. If that doesn't work, then you are going to need to use a switch that is hooked up directly to ground. Based on the last Pyle receiver I saw, you should be able to do the parking brake wire to ground and be fine.
5/19/2010 6:20:20 PM • Pyle PLTS76U Car... • Answered on May 19, 2010
Pyle plts76u shows split screen
I wired my parking bake(brown wire) to the ground wire(black wire), and it allowed me to drive with the screem up
4/20/2010 4:08:48 PM • Pyle PLTS76U Car... • Answered on Apr 20, 2010
I doesn't work
gound pink wire in order to make video play
10/13/2009 5:18:06 PM • Pyle PLTS76U Car... • Answered on Oct 13, 2009
Plts76u started showing split screen. 2 of the same picture.
to solve this problem go to the dvd preference page set up scroll down to defalt by using the remote control press enter on the remote and the system will reset to factory settinn
3/15/2009 2:03:57 PM • Pyle PLTS76U Car... • Answered on Mar 15, 2009
How to drive with dvd playing PLTS76U
eASY... CONNECT THE BROWN BRAKE WIRE TO ANY GROUND IN THE VEHICLE....
3/9/2009 4:17:29 PM • Pyle PLTS76U Car... • Answered on Mar 09, 2009
I need the pinout diagram for pyle plts78dub single din flip out dvd receiver.
Contact Pyle directly to request the information.
3/29/2022 9:43:08 PM • Pyle Car Audio &... • Answered on Mar 29, 2022
I bought a Pyle 4601 A/U from a restore it powers up but only plays sound through subwoofer output. Can it be fixed?
Anything can be fixed. All you need is the expertise and components.
3/8/2021 4:37:55 AM • Pyle Car Audio &... • Answered on Mar 08, 2021
Pyle plbt72g. It isn't working. It just keeps blinking "welcome".
You could see if the companies official website has anything that can help you out.www.helpowl.com
8/10/2020 11:55:36 AM • Pyle Car Audio &... • Answered on Aug 10, 2020
How do I get my pyle radio from going back to calibration every time
The most common explanation for why a car's clock reset is suddenly is due to the battery.This can occur if the temperature has been frigid, the car hasn't been run for a while, or you've been messing around with the electronics after the engine was turned off.
8/3/2020 10:25:56 AM • Pyle Car Audio &... • Answered on Aug 03, 2020
Used the pyle flextreme mp3 earphones for about 3 months for swimming now suddenly its just not charging how to resolve
Your earphone capture some moisture in it, shake it or dry it properly for a while.
6/3/2020 4:20:56 AM • Pyle Car Audio &... • Answered on Jun 03, 2020
Pyle pd3000ba p/n key,video,time,setup,language,zoom,pcb,program,usb/dvd all frozen
No idea what your talking about.......
12/31/2019 8:46:15 PM • Pyle Car Audio &... • Answered on Dec 31, 2019
Pyle PLTS76U Car DVD Player Logo
18 questions posted
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pyle Car Audio & Video
Most Popular Question
wont play while im driving
  • Car Audio & Video
