20 Most Recent
Shredder SH2006PB Questions & Answers
I clogged the shredder by
If the shreder has a toggle switch try to cycle it a few times the may loosen up a piece of paper tha maybe stuck. But chances are if you over fed it and it locked up. You removed all the paper and it still wont work, I would say its damaged. Sorry
Best of Luck
9/22/2009 12:22:27 AM •
Shredder...
Answered
on Sep 22, 2009
Billing
You are not being billed for anything,unless you posted as a Premium or did a olive chat.
The 2 post that you have on here now are both listed in the free section.
Please rate this a fixya by clicking the blue button at the bottom
2/9/2009 1:04:55 AM •
Shredder...
Answered
on Feb 09, 2009
Help my paper shredder is not working.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
6/22/2008 5:26:08 PM •
Shredder...
Answered
on Jun 22, 2008
Office max paper shredder switch
If you are referring to the paper feed sensor switch in the paper throat it sounds like the pc board or switch itself may be bad. I could troubleshoot a little better if I actually had you on the phone. A Customer Service Rep can help you at 1-800-945-4545.
4/29/2008 5:13:07 PM •
Shredder...
Answered
on Apr 29, 2008
My paper shredder only works on reverse.
Either the switch is broken, the throat sensor has failed, or there is a broken wire.
Reverse is a manual operation of the switch. Normal forward is an operation of the sensor plus the switch being set to automatic operation.
