20 Most Recent
Marantz RC3001 Remote Control Questions & Answers
Wizz.it 3 Programing tips
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Rc3001 battery
1) the battery is wrong polarity . Test2) The remote control is faulty. Most of the time the Transistor or I.C for stabilized voltage with the battery is faulty.Your must return to the service shop for guarantee.sincerely. Good luck, and G-d bless youernesto cuadramanagua, nicaragua. c.a
Remote lost program function
Hello, this is Vincent from Total Control Remotes - www.totalcontrolremotes.com. We program a lot of Marantz remotes as well as others and the problem could be a result of many different factors. It could be the programming or a physical reason. My suggestion is to send us the configuration file, we will take a look and confirm that the remote programming is not a problem. We can walk you through a variety of troubleshooting steps with the equipment once we have determined that. There is no real answer however until we do our homework.
Regards,
Vincent
www.totalcontrolremiotes.com
Marantz UD5007 blinking red light then switch itself off
A Marantz UD5007 blinking a red light and then switching itself off may signal a fault or error. It could be due to overheating, disc reading issues, or technical malfunctions. Refer to the user manual for troubleshooting or contact Marantz customer support for help.
11/5/2023 3:57:10 PM •
Marantz...
Answered
on Nov 05, 2023
Marantz Cr401/N1S constantly clicks after power surge/outage.
This can depend on what the player is actually worth. A more expensive player is worth getting a price for the repair. For a more basic, budget machine it often cheaper to just replace it. Your description suggests it is some sort of issue with the disc motor or the lens motor. You will need to get a professional repairer to look at this.
8/4/2023 4:41:45 PM •
Marantz...
Answered
on Aug 04, 2023
Maranta sr6013. Volume will not go past 85.
Make certain DRC (night mode, or whatever your specific model calls it) is OFF, and Make sure that Audyssey Dynamic Volume is OFF and Audyssey Dynamic EQ is ON!
The Dynamic Volume being ON is the most common cause of what you describe, as is directly limits the peak.
4/21/2019 3:15:50 PM •
Marantz...
Answered
on Apr 21, 2019
