20 Most Recent Sony NWZS716FSNC Digital Media Player Questions & Answers
Plug the USB data cable into the and connect the opposite end into one of the USB ports on your computer. The computer states it has detected a new device.
Launch the Sony Media Manager program (either double-click the desktop icon or select "Start," "All Programs" and finally "Sony Media Manager"). The program automatically detects the device.
Select the "Videos" tab, and then click-and-drag a video file into the open window from your computer. The video file location on the computer may vary, depending on where you saved the content to.
Wait for the video files to upload to the (the video files automatically begin uploading to the device once you drag the file into the open program window). Do not disconnect the device from the computer while the upload is being performed. If you do, you may corrupt the device. Once the upload has finished, you may close out the program and disconnect the MP3 player from your computer.
Sony NWZS716FSNC... | Answered on Aug 31, 2010
hello,all you need to do is just to get your mobile phone manual to follow the steps,and you will see a certain code to press inside the manual at the language change under settings,or you probably take it back to your place of purchase for them to assist you on it,if its kind of distanced from your place you can as well call the call center to assist you with the language unlock code.its has simple as that.
thanks,you are highly welcomed.
Sony NWZS716FSNC... | Answered on Mar 22, 2010
Is there a chance you dropped it or got it wet? Or if its new, you can always take it back for another or a refund if you have the receipt.
Sony NWZS716FSNC... | Answered on Jul 20, 2009
if all connected correctly check see if fuses inside or outputs could be blown
Sony Audio... | Answered on Dec 18, 2019
Find out why your Sony is in protect mode and repair it to restore normal operation. This is a common problem with Sony equipment and often is traceable to cold or poorly soldered connections.
Sony Audio... | Answered on Dec 17, 2019
Probably the changer mechanism has failed. You will have to disassemble your Sony unit to salvage the discs. As a test, try playing a single disc. You may be able to use your Sony in a limited way.
Sony Audio... | Answered on Dec 15, 2019
Take it apart an on the rear of the display you will see capacitors. You will probably see an end cap that is domed. Just replace them all.
Sony Audio... | Answered on Dec 10, 2019
Try this and let me know. First unplug the unit. Plug it back in. When you first push the power button, you should hear 1 click followed by another withing 5-20 seconds. My guess is that you don't hear the second click. Am I right?
Sony Audio... | Answered on Nov 30, 2019
You have this backwards. Applicable code(s) will be found in the remote control, if it is compatible.
Sony Audio... | Answered on Nov 28, 2019
Applicable code(s) will be found in a compatible remote control.
Sony NWZS716FSNC  Digital Media Player Logo
4 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
download videos
  • Audio Players & Recorders
