20 Most Recent Starlite Nextplay Fashion iPod Docking Clock Radio NP109CR Questions & Answers
Instruction manual
Which model ipod ?? In keeping with Apple's goal to make user-friendly, streamlined products, the designers of the iPod built in easy-to-use reset functions into each iPod model. Resetting the iPod is similar to rebooting a computer as all songs and data stored on the device stay there, and only temporary information (such as which song is playing) gets reset. Follow these steps to reset an iPod. Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact.
8/7/2013 9:06:35 PM • Starlite... • Answered on Aug 07, 2013
I pods doesn't work after i remove it from radio
I had that same problem too and i had to take my i-pod back because my machine messed it up so thats probably what your going to have to do to the repair shop said that there was nothin they could do and I was better off taking it back and my docking station messed it upso I had to get another i-pod and a docking station-I hope you get the problem fixed
12/28/2009 8:28:06 PM • Starlite... • Answered on Dec 28, 2009
I have a nextplay cd boombox which is brand new and skips
The vibrations from the speakers are causing the cabinet to resonate. This resonation causes the lens to vibrate, distorting the pickup signal... I would recommend giving it a few hard slaps when it skips. if that does not work, then try to adjust the soud so that there is no bass at all if you can.... Else chuck it...
1/24/2009 1:28:35 AM • Starlite Audio... • Answered on Jan 24, 2009
2answers
Sony TA-F210 amplifier no sound
bring data sheet of this ic from the net-check supply voltage(vcc or vdd)-check ground.apply audio signal and test if it is present in input pins after that check your signal in output pins.have a visual inspection around the ic for burnt resistors or bad capacitor. if every thing is fine replace the IC.
11/30/2022 2:31:58 PM • Audio Players &... • Answered 3 hours ago
Where do I get a Panasonic SA-PM11 owner manual please?
Question edited for clarity, add maker, and 'Manuel' is a Spanish gentleman, you need a manual. Owner manual and repair manual in the link https://www.google.com/search?q=panasonic+sa-pm11+service+manual ..
11/29/2022 6:27:32 AM • Audio Players &... • Answered Yesterday
3answers
Can anyone update me about where I can let latest Bollywood Blockbusters?
I recently downloaded an App called Wynk which has all the latest Hindi Music available for you. There are other Apps also which you may install on your phone which provide you latest Bollywood Blockbuster Hindi Music. Check your playstore for the available Apps. https://play.google.com/store/apps/details?id=com.bsbportal.music
11/28/2022 2:01:07 AM • Audio Players &... • Answered 2 days ago
My FM will not play this morning PLAYED GREAT LAST night.
Question edited for clarity. In this category 'AM' is Amplitude Modulation and old radio band. All question need FULL 'make model (what it is)' please. Check that the aerial hasn't become detached or eaten. Make sure whatever the device is, is set to FM.
11/27/2022 1:28:13 AM • Audio Players &... • Answered 3 days ago
I need the remote control codes for Enzer home
Yes
11/24/2022 10:23:45 AM • Audio Players &... • Answered on Nov 24, 2022
My cassette player won't go around on model # 9208M
If your model 9208M cassette player is having trouble going around, there are a few things you can try to fix the issue. First, make sure that the player is properly plugged in and that the power cord is not damaged. Next, check to see if the player's belt is loose or broken. If the belt is loose, you can try tightening it with a Phillips head screwdriver. If the belt is broken, you can purchase a replacement belt from an electronics store
11/24/2022 1:14:50 AM • Audio Players &... • Answered on Nov 24, 2022
Electro-Voice (EV) N/D967 Microphone. I need a wiring schematic for it. The microphone had red and black wires that have become detached.
Question heavily edited for maker, proper model designation, sentences and finish the text for you. Question moved from Laundry Dryers category. https://www.google.com/search?q=ev+nd967+microphone+wiring+diagram ..
11/23/2022 10:10:10 PM • Audio Players &... • Answered on Nov 23, 2022
2answers
FIX MY PCDJ RED NUMARK MIXER VERSION 5.0
Bug in program.... either reset computer date to any month or year prior to 7/2013 ( and set check boxes to not to set clock over internet other automatic time adjust ). OR use a stand alone program to open PCDJ like " RUN AS DATE" ( keeps computer clock normal for other programs and restore,,, etc. ). But requires that you open it in that program each time. If anyone hears of a better fix... please post.
11/22/2022 4:59:37 PM • Audio Players &... • Answered on Nov 22, 2022
My GPX MP3 player 8GB Bluetooth FM player.
Question edited for all the typos and add some capital letters! And I doubt it is a 'record player'. :>D Question moved from Cars and Trucks. The answer is easy. Charge it up! https://www.google.com/search?q=GPX+MP3+player+8GB+Bluetooth+FM ..
11/22/2022 6:19:52 AM • Audio Players &... • Answered on Nov 22, 2022
How do I remove platter from a MCS 6202 turntable?
1. Remove the screws from the platter - This is the first step in taking apart your turntable. You will need to remove the screws that hold the platter in place. Be careful not to lose these screws as they are essential to the reassembly of your turntable. 2. Lift the platter off of the spindle - Once the screws have been removed, you can now lift the platter off of the spindle. Be careful not to damage the spindle as this can cause problems when trying to reassemble your turntable. 3. Remove the felt slipmat - The felt slipmat is there to protect your records from damage. You will need to remove this before you can access the cartridge. 4. Remove the dust cover - The dust cover is there to protect the internal components of your turntable from dust and other debris. You will need to remove this before you can proceed with the next steps. 5. Remove the headshell - The headshell is what holds the cartridge in place. You will need to remove this in order to access the cartridge. 6. Remove the cartridge - The cartridge is the part of your turntable that actually reads the music from your records. You will need to remove this in order to replace the stylus. 7. Remove the stylus - The stylus is the part of the cartridge that comes into contact with your records. You will need to remove this in order to replace it with a new one. 8. Remove the tonearm - The tonearm is the part of your turntable that holds the cartridge in place. You will need to remove this in order to access the motor. 9. Remove the belt - The belt is what drives the platter. You will need to remove this in order to access the motor. 10. Remove the platter - The platter is the part of your turntable that the record sits on. You will need to remove this in order to access the motor. 11. Remove the motor - The motor is what drives the platter. You will need to remove this in order to access the feet. 12. Remove the feet - The feet are what support the turntable. You will need to remove these in order to access the base. I hope this helps/Good luck!
11/22/2022 3:43:16 AM • Audio Players &... • Answered on Nov 22, 2022
2answers
I have a sony sa-va3a sorround 1993 model I trey
Fuses are not your issue. Look in your owner's manual. Find the procedure to return your unit to "Factory Defaults". I'm sure you just have something switched wrong.
11/22/2022 1:02:02 AM • Audio Players &... • Answered on Nov 22, 2022
Creative Inspire T6160. Where can I download drivers?
I would go to www.support.creative.com and get the drivers from the manufacturer.
11/20/2022 11:27:55 AM • Audio Players &... • Answered on Nov 20, 2022
Starlite Nextplay Fashion iPod Docking Clock Radio NP109CR  Logo
Popular Tags
6 questions posted
Top Starlite Audio Players & Recorders Experts
Marvin
Marvin
Are you a Starlite Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Starlite Audio Players & Recorders
Most Popular Question
instruction manual
  • Audio Players & Recorders
