20 Most Recent
Audio Technica ATH-M50 Professional Headphones Questions & Answers
I got a spring problem,
This is what I did after I couldn't find an answer online. Took the fat end, and kind of like a key chain ring, bent the last tiny bit where the spring ends. Then took this bent bit and then like a screw lead that into the jack end. From there just go in a circle and push the next bit of the spring into the jack end in a circle until all of the thicker spring part is back up and under the lip of the jack.
The ath-m50 needs to be burned in?
No, headphone burn-in is largly a myth. While it is possible, from a physics standpoint that the driver material could "break-in" some with use and age, the audible difference would be so slight that it would take specialized equipment to measure the differences, which would be so small as to be unrecognizable by human hearing. Any actual "differences" in sound quality over a period of time is largly based on perception, that is the user gets used to the characteristics of the device. This has been proven time and time again through double-blind tests.
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
