20 Most Recent Sony VPL-EX5 Projector Questions & Answers
change the resolution to 800x600 and if it works raise the resolution step by step
Sony VPL-EX5... | Answered on Dec 18, 2014
Check for bulging capacitors on the power supply board. Replace if found.
Sony VPL-EX5... | Answered on Dec 10, 2014
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Sony VPL-EX5... | Answered on Sep 16, 2014
replace the LCD panels (USD220)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Sony VPL-EX5... | Answered on Mar 01, 2014
initial password is
enter,enter,enter,enter
(enter four times)
Sony VPL-EX5... | Answered on Dec 28, 2013
Change the lamp.
Sony VPL-EX5... | Answered on Oct 13, 2012
Hello
The check the air filter. Clean it first. Turn the power OFF and unplug the device from AC mains. Draw out the air filter cover and remove it. Remove the air filter. Wash the air filter with mild dtergent solution and dry it in a shaded place. Attach the air filter back to device, so that it fits into the each claws on the air filter cover and replace the cover.
If you neglect to clean the air filter, dust may accumulate, clogging it. As a result, temperature may arise inside the unit leading to a possible malfunction. Be sure to attach the aif filter cover firmly. "Power cannot be turned ON" if it is not closed securely.
The air filter will have a face and a reverse side. Place the air filter, so that it fits on a notch on the air filter cover.
If this doesn't help you, check the cooling fan. If fan speed is reduced, proper air circulation will not be ther, as a result the inside of the unit will overheat causing malfunctions, which has not been described anywhere in its manual. If needy, replace the fan. The final possible cause for this fault is with its Lamp itself. Confirm it before replacing, by doing all the above porcedure. OK.
Sony VPL-EX5... | Answered on Nov 03, 2011
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
Sony VPL-EX5... | Answered on May 21, 2011
Remove the lamp and reseat it carefully, following the instructions in the user manual.
If this doesn't help you may find that you need a new lamp.. if you are in the UK you can purchase a Sony VPL-EX5 Lamp here or from here if you are in the USA
Sony VPL-EX5... | Answered on Feb 14, 2011
Its because of dust.Out bulb throw air to bulb and at projector through air blower or vacuum cleaner.You will get better result
Sony VPL-EX5... | Answered on Aug 13, 2010
Sony VPL-EX5 Projector Logo
40 questions posted
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
removed lamp cover error sony vpl ex5
  • Office Equipment & Supplies
