20 Most Recent Hitachi CP-X201 Projector Questions & Answers
How to open the cabinet
On the bottom of the projector should be screws recessed about 3 inches down. There will also be some screws that are visible and some inside of the lamp compartment.
8/23/2014 9:57:48 PM • Hitachi CP-X201... • Answered on Aug 23, 2014
CPX 201 - everything projects
check your cable connection attached to your computer...
4/28/2014 1:38:23 PM • Hitachi CP-X201... • Answered on Apr 28, 2014
Epson ex 7200 projects yellow
RGB Single not work. Check rgb cable
12/29/2013 1:55:06 PM • Hitachi CP-X201... • Answered on Dec 29, 2013
What do I do when I get a box that says to
There is probably dust and dirt blocking the air flow...
Use a spray can of dust remover like you would use on your keyboard and blow out the passageways where the fan pulls the air in and blows it out again...
heatman101
5/9/2011 10:33:45 PM • Hitachi CP-X201... • Answered on May 09, 2011
My projector will not come
you need a new lamp:
http://www.shopvsc.com/Replacement-Lamps-for-Hitachi-Projectors-s/291.htm?searching=Y&sort=9&cat=291&show=50&page=1&f-CP-X201=105087
10/27/2010 3:33:41 PM • Hitachi CP-X201... • Answered on Oct 27, 2010
There is power to the projector and the switch by
If the fan is not on, it is on standby mode. Try pressing the on button for a longer time.
8/10/2010 4:16:17 AM • Hitachi CP-X201... • Answered on Aug 10, 2010
My Hitachi CP-X201 has a flashing red lamp light
Hello :
Did you replace the lamp correctly ? If not , then i'll tell you how to do that :
Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
I hope this will help .
rate please !
If that wasn't helpful , then contact again please !
3/24/2010 2:19:27 AM • Hitachi CP-X201... • Answered on Mar 24, 2010
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
1/17/2010 11:35:09 AM • Hitachi CP-X201... • Answered on Jan 17, 2010
Focal length of projected image
Hi.
This projector was distributed with this lens.
You may have a zoom lens set to maximum zoom, in that case reduce zoom. Check also aspect ratio. See pages 16 17 on manual (Click here).
Minimum distance for this projector is about 38 inches, putting zoom at minimum it should work at 66 inches, size may be still big.
Either than that there is no other setting that can influe on picture size.
If that is still not enough ry calling Projector Doctor form the phone listed on the website below. They will tell you if a lens outside factory specs can be adapted to this projector.
Projector Repair; Replacement Projector Lamps and Bulbs
11/23/2009 8:15:33 PM • Hitachi CP-X201... • Answered on Nov 23, 2009
Yellow tint cp-x201
replaced vga cable
10/28/2009 7:54:56 AM • Hitachi CP-X201... • Answered on Oct 28, 2009
I am trying to connect a Hitachi CP-X201 to a work
does the projector have a rgb output if yes thats your connection.
8/22/2009 5:04:24 PM • Hitachi CP-X201... • Answered on Aug 22, 2009
What causes my Hitachi CP-TW2505 LCD projector to have a green hue?
It goes with the territory of old technology. There is lots of help in the link. https://www.google.com/search?q=Hitachi+CP-TW2505+LCD+projector+green+hue ..
10/15/2021 9:44:57 PM • Hitachi Office... • Answered on Oct 15, 2021
I lost the remote, and accidentally put the key lock on, on my Hitachi cp-x301 projector and not I can only turn it on and off.
https://www.hitachi.com.au/documents/dps/CPX301_manual.pdf Apparently, the usb port on the back can be used to plug in a simple mouse and keyboard to control the projector.
9/27/2020 2:01:54 AM • Hitachi Office... • Answered on Sep 27, 2020
Hitachi CP-X201 Projector Logo
22 questions posted
Top Hitachi Office Equipment & Supplies Experts
ray gallant
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Office Equipment & Supplies
Most Popular Question
hitachi cp x201 flashing red lamp light
  • Office Equipment & Supplies
