20 Most Recent
Tech Solution TS-6000 Shredder Questions & Answers
Where do I get replacement gear for the shredder?
try a appliance repair shop for a supply agent for parts
office supply shops that sell shredders may be able to give you the names of repair agents
if it is more than 5 years old then junk it and get a new one as the cutter rollers will be blunt and probably the reason the plastic gear failed
I have a stripped gear in my TS-6000. How do I
The Tech Solutions shredders have been discontinued for years now. No parts are available. I called the 800 number and was told all parts were liqudated due to discontinuance of the shredders.
We have stripped the gear
Call the 1-800-639-3803 Tech Solutions service hot line, they can provide you with a replacement gear for your TS-6000
Problem ts 6000
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad
pc board, contact manufacturer for more info.
The ability to think logically and creatively
Techs should be able to apply a consistent, logical methodology to the resolution of computer problems. This means that even when confronted with new situation, the tech will stand a good chance of being able to resolve the problem, or at least isolate the problem area. To back up their logical thinking, techs also must be able tomake creative leaps in reasoning when the application of logic fails to produce a satisfactory resolution
