20 Most Recent Sanyo PLC-XL50 Projector Questions & Answers
0answers
0answers
Hi, There was a popping sound
This is an indicator stating the lamp is bad and cannot power the projectors backlight. You should replace this prior to any additional powering of the unit.
9/22/2011 4:02:57 AM • Sanyo PLC-XL50... • Answered on Sep 22, 2011
Sanyo PLC-ZM5000L WUXGA Projector. How do I reset lamp counter on it?? And reset lamp replacement indicator light?? Thank you.
Question edited for clarity and toss in some CAPS. How to Reset a Sanyo Projector Lamp Timer?
  1. Turn on the projector
  2. Press the Menu button and the on-screen menu will appear
  3. Press 3/4 button to remove the red frame pointer to the setting Menu icon
  4. Press the 6 button to move the red frame pointer to the Lamp Counter Reset item and then press Select button
  5. The message "lamp replace counter reset?" appears. Move the point to and then press Select button
  6. Another confirmation dialog box appears and select to reset the Lamp Replace Counter
https://www.google.com/search?q=sanyo+wuxga+plc-zm5000l+reset+lamp+counter ..
5/29/2023 4:39:00 PM • Sanyo Office... • Answered on May 29, 2023
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
  1. Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
  2. Once on the Sanyo support website, click on the "Projectors" category.
  3. Select your projector model, which in this case is the XU 101.
  4. Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
  5. Look for the driver that you need and click on the download link.
  6. Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
3/7/2023 10:53:42 AM • Sanyo Office... • Answered on Mar 07, 2023
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
1/29/2023 6:26:46 PM • Sanyo Office... • Answered on Jan 29, 2023
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak. To solve this issue, I recommend the following steps:
  1. Make sure that the air conditioner is properly plugged in and receiving power.
  2. Check for any visible damage to the unit, such as bent fins or loose wires.
  3. Check the air filter and clean or replace it if it is dirty.
  4. Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
  5. Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
1/2/2023 7:23:05 AM • Sanyo Office... • Answered on Jan 02, 2023
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted. The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red. Nothing can be done about that except replace the LCD imagers. As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
3/9/2022 7:26:25 PM • Sanyo Office... • Answered on Mar 09, 2022
I have a Sanyo Smart label printer and it will not print. It starts, stops and then shuts itself off
Your print head is defective. Not worth fixing
4/5/2019 4:49:05 PM • Sanyo Office... • Answered on Apr 05, 2019
Sanyo PLC-XL50 Projector Logo
Popular Tags
13 questions posted
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Office Equipment & Supplies
Most Popular Question
popping sound
  • Office Equipment & Supplies
