20 Most Recent Panasonic PT-AE700E Projector Lamp Questions & Answers
WHAT IS THROW RANGE ?
8ft to 40.6 foot throw distance. Screen size is 40-400 inches.
9/21/2016 7:06:38 PM • Panasonic... • Answered on Sep 21, 2016
How to reset panasonic projector ae700
Turn on the projector MENU- OPTION- LAMP RUNTIME- Press and hold the ENTER button for 3 seconds. Turn off the power. We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
1/24/2015 3:01:15 AM • Panasonic... • Answered on Jan 24, 2015
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector 2,if the fans run, then ,check the lamp or lamp ballast We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
1/21/2015 11:30:00 AM • Panasonic... • Answered on Jan 21, 2015
Where can i get an optical block for a panasonic
USD150 for the Optical block for AE700 We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
1/21/2015 11:23:41 AM • Panasonic... • Answered on Jan 21, 2015
0answers
2answers
Is this blue tinge on the left side of the screen
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
12/9/2010 5:34:48 PM • Panasonic... • Answered on Dec 09, 2010
My new lamp from Opto Lamps has a plastic tab on
I had the exact same issue with my new Panasonic PT-AE700u bulb. I contacted the company I purchased it from and they authorized the removal of the tab. I used my Dremel tool to slice it off and the bulb ended up working like a charm.
If everything else fits fine...the door just doesn't close, check with the company you purchased the bulb from and see what they recommend. This sounds like a common issue with "OEM" or "Original" bulbs these days.
12/9/2010 6:53:26 AM • Panasonic... • Answered on Dec 09, 2010
How do i replace the
It's in the manual pages 51-52
8/20/2010 10:13:49 PM • Panasonic... • Answered on Aug 20, 2010
How far to mount projector from screen
It depends on a lot of factors -- how bright the area is going to be, the size of your screen, etc -- but you'll be roughly 9 to 14 feet from the screen for most settings.
I'm basing this on numbers for a PT-AE700U projector, as I wasn't able to find the AE700E.
Take a look at the ProjectorCentral.com projection calculator if you want to get precise about the distance for your environment.
But be sure to rate my fix as "Helpful" before you click that link! :)
8/17/2009 1:10:15 PM • Panasonic... • Answered on Aug 17, 2009
3answers
Using the fax machine of Panasonic KX FT981, How
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
9/13/2021 7:35:29 AM • Panasonic Office... • Answered on Sep 13, 2021
How to remove code E03-12 of panasonic copier machine
E03-10, E03-11, and E03-12 means that there is a High voltage problem (Corona, HVT) on the copier machine. E03-12 means that there is High Voltage Power Supply leak You can: - check if HVPS connector is disconnected. - check if HVPS is defective. - check if SPC PCB connector is disconnected. - check if SPC PCB is defective.
9/10/2021 2:54:00 PM • Panasonic Office... • Answered on Sep 10, 2021
Panasonic fax kx mb 2085 call service 4
Panasoic KX-MB 1520 CALL SERVICE 4
6/26/2021 4:51:34 AM • Panasonic Office... • Answered on Jun 26, 2021
2answers
Model dp-mb536. What does 'call service 3' mean?
It means you should contact your local Panasonic servicer and report a code 3 message.
5/20/2021 4:32:17 PM • Panasonic Office... • Answered on May 20, 2021
Model KX-fl612 fax. How can I reset drum counter?
Replacement drums come with the information required.
4/23/2021 6:10:56 PM • Panasonic Office... • Answered on Apr 23, 2021
How do i get ip address on panasonic dp-c265 printer
network settings https://www.manualslib.com/download/599897/Panasonic-Dp-C265.html page 12 could be on dhcp as this is default then log into default gateway router and look at ip leases of dhcp server
3/30/2021 10:09:31 AM • Panasonic Office... • Answered on Mar 30, 2021
Panasonic PT-AE700E Projector Lamp Logo
14 questions posted
Top Panasonic Office Equipment & Supplies Experts
Ekse
Alvin Barnabas
Alvin Barnabas
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
blue tinge left side screen
  • Office Equipment & Supplies
