20 Most Recent InFocus Projector Lamp for IN24+, IN26+ Questions & Answers
to check the lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
InFocus ... | Answered on Mar 21, 2014
to check the lamp
then to check the lamp ballast
have a nice day!
In the menu, go to SETTINGS > SERVICE and choose RESET LAMP HOURS
InFocus ... | Answered on Feb 28, 2011
I would like to know this too. I been searching all over the net and cant find the help. Someone please answer this ;)
InFocus ... | Answered on Aug 22, 2010
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
InFocus ... | Answered on Jun 30, 2010
THere are no filters for the IN24 its a DLP and most dont use filters. Ive had mine apart and i dont see any filters in mine.
There are no filters but i would use a vacuum at the case openings
InFocus ... | Answered on Jun 07, 2010
InFocus ... | Answered on Jun 06, 2010
slide the lamp door off and disconnect the lamp cable then unscrew the screw on the lamp and pull the lamp out.
InFocus ... | Answered on May 27, 2010
either the lamp's seams aren't taped over with foil tape to prevent the premature shutdown due to the heat sensors being triggered, or the fan under the the colorwheel has stopped, maybe due to a piece of lamp from a previous lamp explosion being stuck in it, or the power supply/ballast is bad, or the eca on the engine itself is bad. The lamp is the easiest to try first. There should be foil tape over the seam on the side of the lamp you can't see when it is installed. If this doesn't work, take the front bezel off amd get where you can see the fan under the colorwheel and tunnel and power the unit up and see if the fan comes on. If it does thenthe eca on the engine or the power supply ballast is most likely bad and these are major repairs.
InFocus ... | Answered on May 04, 2010
If you are able to measure/show any continuity whatsoever your bulb is way past bad!!
As these lamps do not have filaments.
If you have replaced the lamp you can easily reset the lamp timer from the projector menu.
This procedure can be found in the user manual as well.
Cheers
InFocus ... | Answered on Dec 30, 2009
there are no replaceable filters. just blow the dust out of the projector with canned air
InFocus ... | Answered on Dec 03, 2009
the lamp may have exceeded 2000 hours. you need to replace the lamp and reset the lamphours. you can check in the menu.
InFocus ... | Answered on Aug 10, 2009
InFocus  Projector Lamp for IN24+, IN26+ Logo
21 questions posted
Top InFocus Office Equipment & Supplies Experts
Marvin
Marvin
Richard C Cohen
Richard C Cohen
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
replace lamp
  • Office Equipment & Supplies
