20 Most Recent Onkyo TX-SR506 Receiver Questions & Answers
2answers
What is the remote control code to control the
hi i have here a couple of codes for Onkyo you could try them 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140, 2006, 2219, 2220, 2318, 2410
hope this help! goodluck!
7/1/2015 9:36:39 AM • Onkyo TX-SR506... • Answered on Jul 01, 2015
2answers
How do I fix my receiver if it is shorting out
units going into protect due to fault - try turning unit on without speakers if unit is ok check speakers
4/17/2015 9:06:16 PM • Onkyo TX-SR506... • Answered on Apr 17, 2015
2answers
Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
4/17/2015 9:04:02 PM • Onkyo TX-SR506... • Answered on Apr 17, 2015
My receiver is shorting out and goes to stand by mode
units going into protection due to fault in unit or speakers
12/1/2014 9:40:03 PM • Onkyo TX-SR506... • Answered on Dec 01, 2014
0answers
Onkyo 506
Be the first to answer 4/26/2014 3:14:13 AM • Onkyo TX-SR506... • Posted on Apr 26, 2014Be the first to answer
0answers
0answers
0answers
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
2/6/2013 5:27:35 PM • Onkyo TX-SR506... • Answered on Feb 06, 2013
3answers
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
1/22/2013 6:30:18 PM • Onkyo TX-SR506... • Answered on Jan 22, 2013
0answers
Memory loss
Be the first to answer 10/23/2012 6:04:14 PM • Onkyo TX-SR506... • Posted on Oct 23, 2012Be the first to answer
Can't find settings to get audio through HDMI hook up.
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/here is a download use it to help guide you. vote for me inform me of your progress
9/19/2012 4:04:19 PM • Onkyo TX-SR506... • Answered on Sep 19, 2012
Can't find a remote code for my onkyo rc-710m to
Remote code will work but be sure you have VIP remote address set on 1. See page 56 of VIP manual or instructions on changing remote address.
1/1/2012 4:33:38 PM • Onkyo TX-SR506... • Answered on Jan 01, 2012
Hi, I have a 3 year old Onkyo TX-SR506 receiver
I don't think its a harmless coincidence that it happened while you were touching it.
Assuming 'damp' means 'no dripping' I'd discount mositure as the cause. Was there something else you may have touched or caused to move during your actions, like speaker wires? Retrace your steps (with power off) and imagine what may have moved.
Disconnect the speaker wires at the receiver and see if that helps. If so, you just need to start adding speakers until it fails again or not, then isolate the cause if it is related to specific channel(s). If it doesn't come up 'naked' something cooked inside and a hands-on tech needs to get involved.
In the future - turn it off when manilpulating anything on, near or attached to it.
7/12/2011 11:18:32 AM • Onkyo TX-SR506... • Answered on Jul 12, 2011
Hi, I have a 3
It is possible that while you cleaned the top with a damp cloth , some drops of water could have fallen on the board and shorted. If so it is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
7/12/2011 11:03:41 AM • Onkyo TX-SR506... • Answered on Jul 12, 2011
Should i use an amplifier
It HAS amplifiers. You don't daisy-chain amps.
Get the manual and take some of the gueswork out of the process. Set it up and come back with specific questions.
Register and download the manual for free at retrevo.com
7/6/2011 1:47:56 AM • Onkyo TX-SR506... • Answered on Jul 06, 2011
Need code for dish network
HeyRodney_tu176, my name is Mike Houston of DISH Network and I was going over yourpost and wanted to give you the codes for your Onkyo TX-SR506 7.1 Receiver. The Codes willbe; 660, 642, 662 and 678. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/remote-setup.
4/17/2011 6:43:07 PM • Onkyo TX-SR506... • Answered on Apr 17, 2011
Onkyo TX-SR506 Receiver Logo
50 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
receiver shorting out goes stand mode
  • Audio Players & Recorders
