20 Most Recent MXL 990 Professional Microphone Questions & Answers
I need replacement rings for the suspension.
I take itypu are talking about the elastic bands for the isolation of the mic. You should be able to find some on eBay or by contacting the manufacturer. Some parts houses carry those items as well. B&H Photo would be a likely one.
2/2/2015 6:41:27 PM • MXL 990... • Answered on Feb 02, 2015
Anybody knows mxl 990 works with behinger usb 302 mixer??
The user manual says Phantom Powered Mic input which means you should be able to use a condenser microphone requireing Phantom Power.
1/24/2015 11:24:39 PM • MXL 990... • Answered on Jan 24, 2015
Repair
If you are good at doing such things yes, but the parts inside are very delicate and must be handled gently as not to damage them. If you are not comfortable doing it then I would suggest taking it to a local music store where similar items are sold to see if they can do it for you.
1/24/2015 11:20:38 PM • MXL 990... • Answered on Jan 24, 2015
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:"routes the microphone signal to a mixer or a microphone preamplifier." • these is just a phantom power supply.One reason your former setup is OK , is that tascam m-50 is a mixer preamplifier. • phantom power supply is just a part of the mic preamp of the mixerto power up your mxl 990 condenser mic • What you may need is something like these: X2u XLR to USB Signal Adapter
10/1/2012 10:27:05 AM • MXL 990... • Answered on Oct 01, 2012
2answers
I have purchased a MXL 990 mic with all necessary
is the mic equiped with a IMPEDANCE selector switch?? is the USB port version 1.x, 2.x or 3.x?? what are the SPEC'S of the computer and the mic???
2/13/2011 6:58:40 AM • MXL 990... • Answered on Feb 13, 2011
Is the 990 an externally polarized capsule or
The MXL 990 is an externally polarized condenser microphone. You will nee to provide 48v Phantom power to use it. Alternatively there is a USB version, the MXL 990 USB which gets it['s power from the USB port.
1/1/2011 6:57:39 PM • MXL 990... • Answered on Jan 01, 2011
I buy a mxl
perhaps there is agrounding issue or the impedance matching is not set properly for this type of condenser mic
look at these reviews
http://www.soundonsound.com/sos/aug05/articles/mxl.htm
http://homerecording.com/bbs/showthread.php?t=163441
hope this helps
10/15/2010 3:34:00 AM • MXL 990... • Answered on Oct 15, 2010
MXL 990 has really low output
These are really cheap mics! I have two dozen of them because what I do requires the mic to be expendable. The capsule is pretty fragile and just a little drop or hit to the mic can drastically alter the frequency response and output level. If you record with it and it has a hollow sound I would bet this is what happened. If you can generate white or pink noise out of your system, then record it. Just hold the mic in front of the speaker. Play it back and compare the tone of the recording to what you just heard. Hollow? There you are!
10/15/2008 6:54:27 PM • MXL 990... • Answered on Oct 15, 2008
I can't any sound from my MXL 990 condenser microphone. Please Help.
The phantom power is 48 VDC measured between pin1 and the pin2, 3.;is the phantom power on and are you using mic inputs not line, the mic cable is a xlr to xlr cable the attached is about phantom power. Always by from established sound centers, they have help by phone, I like sweetwater as they stand behind evry u item they and the don't carry bargain price material. I lije CBI cables as they are american made with quality american cable as swiss connectors. https://cdn.shopify.com/s/files/1/0247/3799/files/phantom_power_primer.pdf
6/18/2018 2:09:21 PM • MXL Audio... • Answered on Jun 18, 2018
My MXL v63m doesnt have sound coming out when plugged in to the amp
It could be any of a number of issues, but when you say "plugged into the amp", this is a condenser mic which requires power from a power supply or phantom power from a mixer. If your plugging it directly into an amplifier, it defiantly won't work.
10/15/2016 2:19:39 AM • MXL Audio... • Answered on Oct 15, 2016
This mic is sensitive. I have moved in a closet in my house. How do you deal with this mic when it still picks up so much air. What can I do?
Your mic may be sensitive but its gain is set in the mixer or computer to which it's connected. I don't know what you mean by "too much air" but if you mean "room sound" there shouldn't be much in a closet unless it has all hard sound reflecting walls. You will need to provide a better description of the problem.
5/13/2015 10:51:00 AM • MXL Audio... • Answered on May 13, 2015
Mxl condenser microphone cuts off intermittently
Failing more obvious things like a dodgy cable, condenser mics need phantom power 48v. Perhaps the phantom is cutting out?
2/26/2015 1:21:38 PM • MXL Audio... • Answered on Feb 26, 2015
My marshall MXL V67 MIC doesn`t work
If this is a condenser micrphone it will require Phantom Power from the mixer you are trying to use it with. If Phantom Power is provided, check the cable to ensure proper wiring.
1/24/2015 11:10:45 PM • MXL Audio... • Answered on Jan 24, 2015
Does djx750 use phantom power
F rom what I see in the user manual no, only a dynamic mic can be used with this unit. A comdenser mic will not be powered.
1/24/2015 11:07:35 PM • MXL Audio... • Answered on Jan 24, 2015
Is there a battery in a mxl 992?
Has it a remove able cover or on the plug? Normally it has the word "Electret condenser" on the body. Is it a lapel type ? Modern units are invariably of this type.
6/29/2014 5:17:39 PM • MXL Audio... • Answered on Jun 29, 2014
MXL 990 Professional Microphone Logo
12 questions posted
Top MXL Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • MXL Audio Players & Recorders
Most Popular Question
need replacement rings suspension
  • Audio Players & Recorders
