20 Most Recent Thomson M140 Microphone Questions & Answers
0answers
I have A thomson M150 mic and when I plugged it in
the same thing is happening to me ?
6/1/2013 7:37:27 PM • Thomson M140... • Answered on Jun 01, 2013
My microphone isent working on
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
3/23/2011 7:52:08 AM • Thomson M140... • Answered on Mar 23, 2011
I have a Thomson clock radio with CD player/AF202X , it was working fine when all the power stopped and I cannot fathom why....?
Check that you have power at the outlet, (by plugging something else in), and check that nothing has chewed the supply lead. After that I would say that the power supply inside the unit has died. Pull it apart and check the voltage(s) with a multimeter but, only if you have some electrical know how and equipment.
2/8/2024 6:05:41 PM • Thomson Audio... • Answered on Feb 08, 2024
Diagrame of Lyra MP3 6675 Reset point
I could not find manual for your device. You can find the manual of similar device from THOMSON Mp3 Player User Manuals Download ' ManualsLib A solution is already available on fixya SOLVED: Thomson lyra 6675 Flash Mp3 Player 2GB - Fixya
11/20/2023 11:58:38 AM • Thomson Audio... • Answered on Nov 20, 2023
How to fix the alarm for Thomson Model CRD-2196A iPod DOCKING, clock, radio, CD unit.
There is no way. The alarm is electronic. The only thing you might try is spraying the alarm buttons with electrical contact cleaner.You could contact them and see if they would repair it.https://images-na.ssl-images-amazon.com/images/G/01/00/00/05/00/21/30/500213070.pdf..
4/24/2022 11:00:03 PM • Thomson Audio... • Answered on Apr 24, 2022
2answers
I need an operational manual for Thomson portable CD player
Hello Jan, tell us what model is your portable CD player Thomson I wait your answer Greetings Franco Dosil Hola Jan, comenta que modelo es tu portable CD player Thomson Espero tu respuesta Saludos Franco Dosil
2/20/2020 10:36:53 PM • Thomson Audio... • Answered on Feb 20, 2020
Thomson wireless Headphones. The red input/power light is not indicating on the base unit where you lodge the headphones. The green charging light is lit up. How can I resolve.
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
10/2/2018 12:32:36 PM • Thomson Audio... • Answered on Oct 02, 2018
Remote code for thomson x101b home theatre system
A "Remote code" for what "device" to talk to your thomson x101b??
2/10/2018 7:00:05 AM • Thomson Audio... • Answered on Feb 10, 2018
User Guide required
http://www.thomsonaudiovideo.eu/ It might be a french product . Not sure if you need to speak french but you could ask them if there is a user manual ? Maybe use a translator web site and put french in as well in your request .
1/25/2018 10:24:30 PM • Thomson Audio... • Answered on Jan 25, 2018
Thomson M140 Microphone Logo
Popular Tags
7 questions posted
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
  • Audio Players & Recorders
