20 Most Recent Sony HT-CT100 Theater System Questions & Answers
Double check to make sure you don't have the "mute" on. Usually a flashing light indicates that the volume has been muted.
Sony HT-CT100... | Answered on Jan 07, 2019
I have the same problem. Anyone have a solution?
Sony HT-CT100... | Answered on Apr 08, 2017
Place under aux. button 5031, this will not control volume just yet. Then press and hold at
Sony HT-CT100... | Answered on Sep 07, 2011
the sub should have its own volume control, you could also buy another powered sub and hook it up instead.
Sony HT-CT100... | Answered on Mar 12, 2011
Try this walk thru program Sony provides. It is really simple and it will walk you thru the connection process. Please let me know if I could help you any further with your dilemma.
Regards, Rick
Sony HT-CT100... | Answered on Jan 04, 2011
You can get the manual on the link below.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HTCT100&LOC=3
Good Luck and please rate 4 thumbs up for the free answer
Sony HT-CT100... | Answered on Apr 26, 2010
The subwoofer deals with low frequencies, which are not very directional (ie, it's harder to tell where the sound is coming from).  So where you put it isn't critical to the sound, provided that it's not behind curtains or something that will soak up sound.  The bigger speaker you have in your subwoofer; the less important the position is.
Putting it in a corner is something you're going to have to try, but you may even end up with better bass if you do, as a corner can act as a soundbox and emphasise bassy sounds.  Conversely, your subwoofer may not like being in a corner and interference effects from the sound reflections could degrade the sound.  Like I say, try it and see what it sounds like.  It depends upon your subwoofer, what else is in the corner, precise positioning, and how reflective to sound the corner is.  If it sounds terrible, move it a few inches and try again.
You can put it in front of you next to the TV, no problem.  The only downside it it's a big ugly box.  My wife always makes me hide my subwoofers behind something.
Sony HT-CT100... | Answered on Mar 23, 2010
the blue ray player and tv have different inputs. Unless you are using a cable box, dish or whatever, you can try hooking it up with the same cable.
But sounds like your tuner card may be bad. I have seen it a few times. Is there any other way you can hook this up without the input you are using for tv?
Sony HT-CT100... | Answered on Feb 18, 2010
Protector mode does not just react to ambient temp. Try unplugging all the speakers from the back of the unit and turning it on. If it continues to go into protect mode, it is most likely a bad power supply or possibly a bad D/A circuit. If it does not go into protection mode when the speakers are disconnected, try hooking up one speaker at a time (while the unit is off) If the unit faults again when you turn it back on, it should point toward a bad speaker or crossed wires.
Sony HT-CT100... | Answered on Dec 28, 2009
Yes, you need to change your settings.
Follow this advice:
http://www.avsforum.com/avs-vb/showpost.php?p=15172017&postcount=745
Sony HT-CT100... | Answered on Dec 06, 2009
Sony HT-CT100 Theater System Logo
Popular Tags
34 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
like upload manual
  • Audio Players & Recorders
