20 Most Recent Polk Audio DSW PRO 500 Subwoofer Speaker Questions & Answers
Help with repairing this product, Polk suggests replacing the amp !!
To troubleshoot this you need at least an ESR meter. Capacitors can fail with no outside indication.
6/19/2016 11:56:44 PM • Polk Audio DSW... • Answered on Jun 19, 2016
2answers
No power. Fuse was blown but replaced fuse and still no power.
If fuses blown there is a case to search for short circuited active parts examples are end-transistors caused by clipping speakers cable shorts leaking or convexed capacitors but any new fuse will blowing again and again also the bridge rectifier to make dc voltage inside the power supply of the subwoofer can caused this problem
5/15/2016 8:36:44 PM • Polk Audio DSW... • Answered on May 15, 2016
0answers
0answers
Polk Audio DSW Pro 500
Is this NEW? Or did it just fail spontaneously after working for awhile? Is this just a remote control issue or is the sub dead, too? From the manual... No sound coming from subwoofer. If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct. Subwoofer has no power. Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord receptacle. Fuse type and rating is found on the back panel. Remote control doesn't work. Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked. If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
3/6/2011 10:01:29 PM • Polk Audio DSW... • Answered on Mar 06, 2011
Got a brand new dsw
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
11/20/2010 9:30:13 AM • Polk Audio DSW... • Answered on Nov 20, 2010
Can replace my polk audio fuse with a T3.15A 250v fuse
It depends on what it is on, but I am seeing mention of a 1 POINT 6 (1.6) amp fuse so NO to a 15 amp fuse. Fuses are there to protect against shorts or overloads. The fix is not to put in a fuse that is 10 times bigger, or you burn out components or wiring. Fix the reason the fuse blew, normally take to an audio electronics engineer. fuse (1.6A) 120vac https://www.google.com/search?q=polk+audio+fuse ..
7/9/2023 10:59:14 PM • Polk Audio Audio... • Answered on Jul 09, 2023
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i... Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound . Solution to my Protect Mode Problem - Polk Audio Forum Feb 15, 2010 Speakers causing the Power Amplifier to go into protection ... May 9, 2016 PA D4000.4 starts up in protect mode? - Polk Audio Forum Aug 22, 2012 PA880 Help Needed - Protection Light - Polk Audio Forum Apr 3, 2013 More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote... One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
1/27/2022 1:02:36 AM • Polk Audio Audio... • Answered on Jan 27, 2022
3answers
My polk subwoofer makes a heartbeat sound and is
Power off the sub. Push the reset then power back on.
11/1/2019 1:14:21 PM • Polk Audio Audio... • Answered on Nov 01, 2019
I need owners manual for Polk audio SDA 1c
I used http://www.google.com and entered the words Polk audio SDA 1c The only manual or information besides several youtube videos I saw was this which may not be helpful to you: http://www.vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf http://www.vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
4/10/2018 12:40:50 PM • Polk Audio Audio... • Answered on Apr 10, 2018
I have a Polk audio PWS 110 powered subwoofer. Static sound is coming from the speaker. I have checked all the connections and everything appears to be ok.
go to the hardware store and buy a cheap plug-in polarity checked for the electrical socket. If the polarity is reversed, or your ground is improper is will give you a different colored light. Polarity is easy to reverse. Shut off the main breaker box in your home and simply take the cover off the outlet and swap the two wires with the narrow and wider blades on them. Make sure the ground wire is actually grounded to something like a water pipe of connected to the house ground rod, #4 rebar, 18 inches long with a thick copper wire and brass auto batt connector will work fine... bury it deep and remember where it is in the flower bed underneath a window sill outside. If the subwoofer is near the TV, you made be getting interference from it, if the cabinet is not shielded against RF.
9/2/2017 7:19:51 PM • Polk Audio Audio... • Answered on Sep 02, 2017
My Polk Audio model DSW1000 and the main fuse keeps blowing.I found a crack in Thermistor TH1 lokks like some parts is short in the board.Do you know which parts I need,some kind of a kit to repair
There is no kit and if you don't know how to test and repair this type of electronics then you need to take it to a repair shop. Polk charges around $250 for the repair. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
8/25/2017 8:19:36 PM • Polk Audio Audio... • Answered on Aug 25, 2017
Polk Audio DSW PRO 500 Subwoofer Speaker Logo
11 questions posted
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
k24674
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Polk Audio Audio Players & Recorders
Most Popular Question
help repairing product polk suggests
  • Audio Players & Recorders
