20 Most Recent Lite On Da-Lite Perm-Wall 240" 4:3 Projector Screen Questions & Answers
Hi Tony- I found this link to download a copy of the manual. https://www.scoop.it/topic/jtzkncj/p/4100874528/2018/08/21/lite-on-lvw-1107hc1-manual Hope this helps.
Lite On... • Answered on Dec 03, 2019
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Lite On... • Answered on Aug 22, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Lite On... • Answered on Jan 17, 2017
try nte.com semiconducter
Lite On... • Answered on Jan 02, 2014
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
Lite On... • Answered on Dec 25, 2013
Look for a tiny hole in the front of the tray. Use a paper clip to press in on it. Should pop out easily.
Lite On... • Answered on Nov 04, 2013
Try to Google the model number with "remote"
Lite On... • Answered on Dec 03, 2012
then take it to the electrician
Lite On... • Answered on Oct 31, 2012
Lite On Da-Lite Perm-Wall  240" 4:3 Projector Screen Logo
0 questions posted
Top Lite On Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Televison & Video
Most Popular Question
change lite lvc 9016g from ntsc pal
  • Televison & Video
