20 Most Recent Lite On Da-Lite Tensioned Executive® Electrol® 85" 1:1 Projector Screen Questions & Answers
Manuel for LVW 1107 dvd recorder lite on
Hi Tony- I found this link to download a copy of the manual. https://www.scoop.it/topic/jtzkncj/p/4100874528/2018/08/21/lite-on-lvw-1107hc1-manual Hope this helps.
12/3/2019 1:34:21 PM • Lite On... • Answered on Dec 03, 2019
Lg60pb6650 stand lite on -turn on with remote relay clinks -screen flashes gray - then repeats -found 2nf capacitor blown on upper buffer board-tried to replace the capacitor but hard to do. Reinstall
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
8/22/2017 6:12:57 PM • Lite On... • Answered on Aug 22, 2017
0answers
TLX-04243B Dead set Red blink lite on right front corner
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/17/2017 7:18:32 AM • Lite On... • Answered on Jan 17, 2017
2answers
I am looking for parts for my liteon lvw-5055gdl
try nte.com semiconducter
1/2/2014 11:43:23 PM • Lite On... • Answered on Jan 02, 2014
-DVD Door will not open :(
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
12/25/2013 7:39:08 PM • Lite On... • Answered on Dec 25, 2013
0answers
Dvd wont eject
Look for a tiny hole in the front of the tray. Use a paper clip to press in on it. Should pop out easily.
11/4/2013 9:32:57 AM • Lite On... • Answered on Nov 04, 2013
0answers
No remote control for LITEON LVW-1105HC+ DVD RECORDER
Try to Google the model number with "remote"
12/3/2012 10:29:11 PM • Lite On... • Answered on Dec 03, 2012
Dvd door wont open
then take it to the electrician
10/31/2012 10:26:33 AM • Lite On... • Answered on Oct 31, 2012
Lite On Da-Lite Tensioned Executive® Electrol®  85" 1:1 Projector Screen Logo
0 questions posted
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Televison & Video
Most Popular Question
change lite lvc 9016g from ntsc pal
  • Televison & Video
