20 Most Recent Olympus WS-311M Digital Voice Recorder Questions & Answers
I had the same problem on a WS 311 and this worked for me as well, thanks so much!
Olympus WS-311M ... | Answered on Sep 11, 2014
Sounds as if you need to format the device. Go to the Menu - to Submenu press Ok - go to Format press Ok - Click start -
This will permanently erase all data and reset the memory so you will have the maximum amount of recording time again.
Olympus WS-311M ... | Answered on Jul 19, 2012
Unfortunately, this item does not contain a Serial Number. These items were produced with Model Numbers only. You can access the system information by selecting sub-menus within the device. If you do not know how to do that, I can provide you with a detailed Operators Manual. Please send me and email and I will attach the manual for you. [email protected] Lawrence Brown
Olympus WS-311M ... | Answered on Sep 26, 2011
Yes, the files are likely corrupted. You can try a file recovery program such as PC Inspector Smart Recovery. Search snapfiles.com for a free download.
Olympus WS-311M ... | Answered on Apr 27, 2011
You must first make sure that the files are indeed good. Install VLC (which doesn't needs external codecs)
http://www.videolan.org/vlc/download-macosx.html
and try to play the wma files with it. If it fails then the files are corrupted. If it works then either the codec pack has been removed - reinstall it from
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=915D874D-D747-4180-A400-5F06B1B5E559&displaylang=en
or the files were coded in a format Easywma can't support - like the lossless and voice one, or with DRM. If it's the last case then configure the recorders accordingly.
Olympus WS-311M ... | Answered on Apr 10, 2011
Dont know where you looked before but you should be able to get the full user manual at
www.olympusamerica.com
Olympus WS-311M ... | Answered on Feb 22, 2011
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Olympus WS-311M ... | Answered on Sep 30, 2010
I've been having the same problem recently. It seems it might be low battery power. When I turned my recorder on, the battery was showing three bars, then down to two, but one would think it should still function with two bars.
However, before I went to buy a new recorder I decided to put a new battery in. So far it has not messed up again with the new battery. I'm pleased because I've used the heck out of my recorder and LOVE it...don't want to have to buy a new one.
Olympus WS-311M ... | Answered on Sep 23, 2010
It should be on the side of the recorder,visible after you remove the battery or it may be on a decal on the back of it
Olympus WS-311M ... | Answered on Mar 30, 2010
Pull the battery out and let it sit for 2 minutes,reinstall the battery,if that doesnt work save your recordings,and then format the recorder.If still no success,send it in to olympus for service
Have you tried rebooting your pc and do you have admin privleges if your running vist or 7?
Also make sure you put a fresh battery in the recorder,allow it to boot up and settle.Then separate the recorder,make sure the hold switch is not on hold and see if your pc recognizes it as a drive under my computer
Olympus WS-311M ... | Answered on Mar 26, 2010
good day, you might want to try this link for you to update you windows and hopefully the error code will be gone. hope this helps, have a nice day
http://go2.wordpress.com/?id=725X1342&site=strom.wordpress.com&url=http%3A%2F%2Fdrmlicense.one.microsoft.com%2FIndivsite%2Fen%2Findivit.asp
Olympus WS-311M ... | Answered on Feb 12, 2010
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
The only thing is send unit to service
Olympus WS-311M ... | Answered on Feb 07, 2010
Check out this link below to download a PDF manual, and more for your recorder. Just copy and paste into your browser.
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1308
Hope this helps, let me know if I can do anything else for you.
JimmyC
Olympus WS-311M ... | Answered on Oct 13, 2009
Olympus WS-311M  Digital Voice Recorder Logo
30 questions posted
Top Olympus Audio Players & Recorders Experts
Lee Hodgson
Lee Hodgson
Richard Schabler
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
software easywma converter mac suddenly
  • Audio Players & Recorders
