20 Most Recent
Quartet gbc RDS1819 Shredder Questions & Answers
I have a gbc heatseal h535 turbo laminator that
I had the same problem. It's prob the optical chopper/encoder wheel on the motor shaft that wobbled loose and scraped on the sensor until plastic filings plugged up the holes. remove cover and check the "u" type sensor the chopper wheel runs in. Mine was really crammed full of plastic so I had to take it it off and pick it out with a blade. when you reinstall make sure wheel runs between sensor with no scraping.
Shredder is squeaking
You would need to lubricate the unit by running through oiled paper or by spraying oil directly into the feed opening and then running unit in reverse for at least 2 minutes
Good luck
