20 Most Recent Ricoh Aficio 1515 Black and White Copier Questions & Answers
How do I stop printing from RICOH 1515 from fax
You might have this fixed already. If not, you may help me help you by saying what happens. Does the machine show a jam because paper is a different length than programmed into machine? This may cause machine to never "complete" printing your received fax. I will see if anything else comes to me.
11/26/2014 4:31:21 AM • Ricoh Aficio... • Answered on Nov 26, 2014
0answers
Ghost image
Be the first to answer 12/10/2013 7:45:01 AM • Ricoh Aficio... • Posted on Dec 10, 2013Be the first to answer
Ricoh aficio1515f ink spread on the drum.what is the problem?
ereur E-06 RICOH JP1215
4/11/2013 6:13:49 PM • Ricoh Aficio... • Answered on Apr 11, 2013
Paper tray is full but
Hello!
You already found the problem. That sensor is the paper sensor. It probably is broken. You need to replace it or glu it.
9/12/2011 6:38:03 PM • Ricoh Aficio... • Answered on Sep 12, 2011
Problem is : follow instrctns
close right cover
3/11/2011 4:32:52 PM • Ricoh Aficio... • Answered on Mar 11, 2011
2answers
My Ricoh Aficio 1515 won't fax anymore. What do I
more detailes please
1/25/2011 8:04:26 PM • Ricoh Aficio... • Answered on Jan 25, 2011
Do you service Ricoh like the 1515 ? I am a
i'm with yo if yo need some thing talk to me i will be with yo
1/18/2011 11:46:52 AM • Ricoh Aficio... • Answered on Jan 18, 2011
I do not want a Communication Result Report after
This is a somewhat complicated change. You must change the user parameter "switch" to turn the automatic printing of the transmission result report off. If you have your Facsimile Reference Manual "Advanced Features" then just go to the user parameters section and go thru the steps. If you do not have your manual you can download for free here.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Be sure to get the advanced features facsimile manual.
Sorry for the referral to a manual but you will see what I mean, it is just too much stuff to type here and the manual has pictures of the display as you go.
Good Luck and Thank You for using Fixya.
9/22/2010 8:44:13 PM • Ricoh Aficio... • Answered on Sep 22, 2010
The copy light and load paper light is on at the
Remove your paper tray and look for paper behind the tray.
8/11/2010 5:54:44 PM • Ricoh Aficio... • Answered on Aug 11, 2010
The copier is jammed - the copy light and load
Have you removed the paper tray to see if there is a piece of paper behind the tray ? Paper will frequently go behind the tray and wind up in the size switches and or the tray lift gears.
I would check that first. Let me know.
8/11/2010 5:54:03 PM • Ricoh Aficio... • Answered on Aug 11, 2010
We were getting streaky lines, it also ask us to
Are you getting these lines when copying? Or Printing?
Or both. Are these dark lines or blank lines?
If it is just when copying, try making a copy by laying an original on the glass rather than using the feeder. If this copy comes out clean then you need to clean the ADF (Automatic Document Feeder) scanner glass. Just open the section where the documents are fed into and you will see a strip of glass that runs from front to back, about an inch wide. Clean this with a soft cloth and a bit of glass cleaner.
If this works then great. If not then reply back with more details and I will help you further.
6/9/2010 11:02:52 PM • Ricoh Aficio... • Answered on Jun 09, 2010
My ricoh keeps telling me that the toner is
Sometimes with those small copiers, the cap from the old toner bottle will remain when you put in a new bottle. Take out the toner bottle and look in the mouth of the toner hopper (where the top of the bottle sits) to make sure there isn't a plastic cap with two fins on it sitting there. If it is there, that's your problem -- just throw it away.
If there's no old toner cap there, make sure the toner bottle is sitting on the hopper tray and the tray is pushed in, snapped into place, and the green handle on the front is in the downward position. If the toner hopper isn't pushed in all the way so it snaps in, the machine won't be able to load toner.
If neither of these scenarios is the problem, check to make sure you have the right kind of toner. I believe for a 1515 it should be type 1170D, but you might want to check your owner's manual to be sure.
6/5/2010 12:37:54 AM • Ricoh Aficio... • Answered on Jun 05, 2010
Trying to send document from laptop. Never had a
when you press the printer btn on the copier what does it say in the window ?
4/18/2010 10:59:51 PM • Ricoh Aficio... • Answered on Apr 18, 2010
Ricoh 1515. paper out light comes on continually
The lights are misaligned with the paper, meaning that it doesn't sense the paper.
Sensor problem.
2/16/2010 1:14:22 PM • Ricoh Aficio... • Answered on Feb 16, 2010
I WANT TO PRINT DOCUMENTS FROM MY MAC BOOK. I HAVE
In order to print from a mac you'll need the PostScript option. It's a proprietary SD card that plugs into the upper SD slot on the expansion module.
7/30/2009 12:01:25 AM • Ricoh Aficio... • Answered on Jul 30, 2009
I need a manual for a rich aficio 1515 mf cannot
The PCU is removed by opening front door and right side door.Black PCU will have one electrical connector on front, very visible, that needs to be unplugged with machine turned off, push a little black plastic guide on left side of PCU and it should pull forward and come all the way out. Putting the new one in is reversed, except there will be a plastic strip that has to be pulled off before installation. Good luck, please rate this. Thanks
7/2/2009 1:20:56 AM • Ricoh Aficio... • Answered on Jul 02, 2009
Double sided is no longer an option with mac os 10.5.4
Go into the advanced settings of the driver and look for the settings that tell the copier what features you have. Make sure the duplex is turned on. Normally I set these up for Windows use and I have one client who uses a Mac and he did show me that the features do exist for the print driver.
Once it is enabled the double sided printer feature should work.
1/2/2009 7:10:14 PM • Ricoh Aficio... • Answered on Jan 02, 2009
Hi Everyone, my 1st post so hope someone can help. I have Error codes on Ricoh SG7100DN printer. The codes are SC (93300)
93300 HRB (Head Relay Board) fuse blown Mounted on the top part of the carriage unit.
7/22/2021 12:06:05 AM • Ricoh Office... • Answered on Jul 22, 2021
I have a Ricoh SP C261SFNw printer (6 months old) and it appeared the error SC 542. How can I fix it? I'm in Argentina
Ricoh SP C261SFNw printer error SC 542 5. Execute "Reset Fuser Unit" with the "Engine Maintenance" menu if the fusing unit is replaced. "Menu Mode" can be executed by depressing the following key sequence while in ready condition: Clear/Stop, 1, 0, 7 and Color Start. (Press and hold each key till a beep is heard.) 6. Scroll to Engine Maintenance - Enter 7. Scroll to Reset Fuser Unit - Enter
7/8/2021 1:27:04 AM • Ricoh Office... • Answered on Jul 08, 2021
Ricoh Aficio 1515 Black and White Copier Logo
Popular Tags
39 questions posted
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
not want communication result report
  • Office Equipment & Supplies
