20 Most Recent Minolta DI2510 Black and White Copier Questions & Answers
AT DC sensor abnormal please insert new developer
Minolta DI2510... | Answered on Sep 09, 2016
code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta DI2510... | Answered on Jun 18, 2016
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Minolta DI2510... | Answered on Nov 14, 2015
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Minolta DI2510... | Answered on Mar 01, 2015
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta DI2510... | Answered on Feb 21, 2015
what code do you want to reset different code different reset procedures
Minolta DI2510... | Answered on Feb 20, 2015
Has the drum developer and cleaning blade been replaced? If not then the copier will think all three are new and will adjust High Voltages as require. When in reality the they are not new> Causing image problems and service codes. DO it right have it done right, Like clear counters first then replace the parts then run the required F8.
Minolta DI2510... | Answered on Feb 18, 2015
Need the developer and drum to be replace along with developer unit. IF that has been done then who ever did it did not clear the counters for those things. now you will need new developer. Was the F8 run after develop was changed. If not that could be cause. Machine works off the machine counters if they where reset and the parts where not replaced the machine will adjust the required voltages to certain parts thinking they are new when their old and you will get codes and image problems GET a qualified Konica Minolta tech out do it correctly.
Minolta DI2510... | Answered on Feb 08, 2015
Where is the miss feed detected 1,2,3,4 draw or bypass tray?
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip for that only :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Minolta DI2510... | Answered on Feb 07, 2015
Sir/Mam, First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Minolta DI2510... | Answered on Feb 04, 2015
Sir/Mam,
got to the following web site. Self Help Product Support Konica Minolta Business Solutions Inc
Minolta DI2510... | Answered on Jan 25, 2015
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Minolta DI2510... | Answered on Jan 23, 2015
Have you had the develop and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready To Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can not print anything unit the F8 is run. Or you start over.
Minolta DI2510... | Answered on Jan 22, 2015
First paper draw lift open the draw check behind it ensure no paper stuck back there. REMOVE any STORED EXTRA paper from the draw the extra space is not for paper but if you decide to put 11x17 paper in the draw you need the space.
Minolta DI2510... | Answered on Jan 04, 2015
Default password admin is 00000000 or12345678 unless changed by previous owner? Can be reset in service mode
Minolta DI2510... | Answered on Dec 30, 2014
C0F32
Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Minolta DI2510... | Answered on Jul 23, 2014
Minolta DI2510 Black and White Copier Logo
36 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
code problam di2510
  • Office Equipment & Supplies
