20 Most Recent Minolta bizhub 200 Copier Questions & Answers
what is the issue?????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta bizhub... | Answered on Jan 24, 2016
Exit Paddle Solenoid (SL2-FN)
Exit Paddle Home Position Sensor (PC11-FN)
Main Control Board (PWB-A FN)
one of the above on the finisher is not working or is jammed
Minolta bizhub... | Answered on Nov 19, 2015
utility/counter stop 00 stop 01 go to Settings in the Administrator # Initialize and change pw
Minolta bizhub... | Answered on Nov 14, 2015
go user settings/choice setting tab #6 set default tray to what you want
Minolta bizhub... | Answered on Feb 22, 2015
Inside the image unit. which is the assy in the machine right side cover that has the two handles on the green looking item
Minolta bizhub... | Answered on Feb 19, 2015
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
Minolta bizhub... | Answered on Jan 31, 2015
Try this first if it does not work you need a new screen/control panel.
1,. Take a paper clip with machine on and stick it in the tiny hole on the right side of the control panel the screen will change when you see the screen with copiers and computer look under the computer on left side of the screen see a small dot. when it shows press the "3" key go touch panel adjust follow the screen see if that reset the screen if not need a new one.
Minolta bizhub... | Answered on Jan 04, 2015
Sir/Mam, Go to
1. Admin Management
2. Admin #1
3. Reports Settings and or Print list that should give what you want.
Minolta bizhub... | Answered on Dec 30, 2014
Bypass tray? or draw? which one? or large capacity draw?
Minolta bizhub... | Answered on Dec 06, 2014
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Minolta bizhub... | Answered on Jul 04, 2014
I would start with the easiest solution, look to see if there is any paper jammed behind the paper tray. There are switches behind the paper tray for paper size. Also, make sure the paper tray guides are in the correct position against the paper in the tray, they tell the copier the paper size. Good Luck
Minolta bizhub... | Answered on Dec 24, 2013
My Bizhub pro 920 Error Code SC35-02
Minolta bizhub... | Answered on Jul 23, 2013
problem in hv unit ( ch corona ) in drum unit replace if necessary
Minolta bizhub... | Answered on Jan 20, 2013
Use the hand feed tray on the right side. When you put paper in this tray it usually will ask you to set the paper type. 110 lb. card stock is EXTREMELY difficult to copy onto. It might be better to bring this particular job to a copy center. This type of stock will put serious wear on your machines drum. Drums cost big money. Good luck.
Minolta bizhub... | Answered on Jul 15, 2011
Press the "utility" button.
Minolta bizhub... | Answered on Jan 05, 2011
This means that imaging unit of your photocopier machine should be replaced.its life is over now.
Minolta bizhub... | Answered on Oct 07, 2010
Minolta bizhub 200 Copier Logo
Popular Tags
32 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
code sc35 02 biz hub pro c500
  • Office Equipment & Supplies
