20 Most Recent
Motorola Talkabout SX900R Two Way Radio Questions & Answers
We can not get out 2 way radios to communicate
I am sure you the radio's both set on the same channel. But what about the sub-channels? Are those the same? On the screen, the large number is your channel. The smaller number below it is the sub-channel. They should match. If you've already done this and the radios still will not communicate with each other, then find someone locally (that is fluent on radios) to look them.
Otherwise, return them.
Not sure this helps you short of having more information. Please let me know.
Good luck.
K
Motorola...
Answered
on May 09, 2011
I need to wire external
usually when buying a 2way radio they come with a headset (a headphone and a mic) all you need to do is cut the mic and headphone off using the wires for the headphone solder them to a speaker.
(the higher the power of the speaker the more it will drain your battery)
Motorola...
Answered
on Mar 22, 2011
What's the quickest way to drain the battery?
Simply leave the radio turned on overnight. Most TalkAbout radios have a 12-18 hour battery life. Pressing the PTT button can also speed the process but is not recommended, as it would cause wear and tear on the radio, and possibly shorten the life expectancy.
FYI: The rechargeable batteries with the TalkAbout radios typically do not need discharged before recharging, as they are either NiMH or Li-Ion and have very little memory effect.
Best regards.
Motorola...
Answered
on Apr 10, 2010
What code to use for motorola sport 7 walkie
Sport 7 radios were sold before the "interference eliminator code" was a standard option. In most cases setting your other radios to code zero would match the Sport 7 radio.
If this does not solve your problem please post another question and list the model of your other radio you are trying to use with the Sport 7.
Best regards.
Motorola...
Answered
on Nov 17, 2009
