20 Most Recent Midland LXT345VP3 Two Way Radio Questions & Answers
Avph3 beeps when you try to talk
there is a call button that is an option maybe you can switch off the beep call or the info is in your manual
6/12/2014 8:59:45 AM • Midland... • Answered on Jun 12, 2014
We have a problem with one of the hand sets. It
  • Check the settings of the CTCSS tones on both radios and make sure they are the same. It would seem if you are hearing a transmission from the other radio but cannot transmit out of that same radio than that radio is malfunctioning. It may be time for a new pair.
Regards, Tony
4/28/2011 9:24:13 PM • Midland... • Answered on Apr 28, 2011
Midland 78-999 40 Channel SSB/AM CB Radio Base Station. I am looking a user manual pdf
Question edited for clarity. https://www.transmission1.net/viewtopic.php?t=58817 Or Paper copies
VHTF MIDLAND 78-999 AM/SSB Transceiver Owners ...
eBay https://www.ebay.com > Manuals & Magazines A great manual for the classic 78-999 AM/SSB CB base station which is a Legend ... VHTF MIDLAND 78-999 AM/SSB Transceiver Owners Manual with 5 Schematics! US$29.95 · ‎In stock
Midland 78-999 AM/SSB CB Radio Owners Manual w ...
eCRATER https://theclassicmint.ecrater.com > midland-78-999-a... Complete OPERATORS manual with schematics. This is not a service manual, this is the owners manual the radio came with. As shown, mint condition as NEW. US$31.95
6/4/2023 4:20:21 PM • Midland Radio... • Answered on Jun 04, 2023
Where can I get a 12volt dc power cord. For a midland hand held 75-779 cb radio
any place that sells electronics
9/20/2021 12:54:31 PM • Midland Radio... • Answered on Sep 20, 2021
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance. 15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ... 8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
8/18/2021 11:21:07 PM • Midland Radio... • Answered on Aug 18, 2021
Midland two way radio 7Q-0351C What size fuse is require on the 12 VDC power lead?
I think you meant 70-0351c? I believe this is a 60 watt transceiver. So if you remember ohms law P=IxE or power equals amps times volts so 5 amps times 12 volts equals 60 watts. Use a 5 amp fuse.
8/29/2019 7:24:32 PM • Midland Radio... • Answered on Aug 29, 2019
2answers
Need a manual for midland 79-265
If its a real old radio Midland may not have it---Google that model number with "manual" to see what is available.
5/30/2019 1:05:06 PM • Midland Radio... • Answered on May 30, 2019
Hi . I want to buy midland gxt 1000vp4 two way radio . But the charger of that is US standard 110 /60 . In my country its 220/50 . So is there is an eazy way to make it work ? .. thanks.
go to radio shack or best buy you need a step up transformer .or you can buy a travel kit and you dont need a lot of watts transformer to do this dont let them rip you off on a high watt one.
3/1/2019 5:42:49 PM • Midland Radio... • Answered on Mar 01, 2019
Want to know if I can silence call beeps compleatly on all my radios. Midland X-talker T50 Series...Thank You
Yes. They call it silent operation. To set SILENT OPERATION, press the MENU button until the display shows a "bP" icon. Select "on" or "oF" by pressing the s\t buttons and push the PTT key or MENU button.
11/2/2018 6:42:07 PM • Midland Radio... • Answered on Nov 02, 2018
Regarding the Midland 1050 Two-way FRS/GMRS radios, are the corresponding wattage outputs for the transmitting power levels of L, M, and H .5, 2, and 5 watts respectively?
Not on FRS. FRS has only one power level and it's set to low. GMRS ERP output on the 1050 is approximately 0.4w low; 1.5w mid; and 3.07w High according to operator blogs.
9/30/2018 3:07:19 AM • Midland Radio... • Answered on Sep 30, 2018
I need the wire diagram for a midland extension speaker model 21-406
There are only 2 wires for the speaker. It doesn't matter how they are connected to the radio. Switching the wires will not make any difference.
1/27/2018 5:18:01 PM • Midland Radio... • Answered on Jan 27, 2018
Is the Midland micro mini mxt90 repeater capable.
I would say no, it's not repeater capable for widespread use. After taking a look at a photo of this radio, I don't see any buttons to program a specific frequency that would allow listening to a nearby repeater. The GMRS frequencies for this radio, probably in the 462.000 range, are preprogrammed and locked in. If you're lucky, you might discover a repeater in your area on the UHF band in this range - just for listening. It would require a FCC license under Part 97 of the FCC rules to transmit. The GMRS radios can be licensed under Part 95, mainly for family members to communicate with each other. Hope this helps.
1/18/2018 3:40:44 AM • Midland Radio... • Answered on Jan 18, 2018
Midland LXT345VP3  Two Way Radio Logo
2 questions posted
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Midland Radio Communications
Most Popular Question
problem one hand sets
  • Radio Communications
