20 Most Recent Uniden TRU9585 Cordless Phone Questions & Answers
3answers
My uniden phone says - out of range
Uniden wxi477 out of range fixThis problem arises when the handset does not communicate with the base.These are the steps:1: Deregistering the handset 2: Registering the handset to baseDeregestering clears the stored (incorrect) base information on the handset.Reregestering allows the base to assign a new ID for the handset.Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.Registering the handset with the base- Make sure the tel. line and power is plugged into the base.Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.Check your connections on the base and make it is getting power.The Steps above was my fix for the uniden wxi477 out of range problem.Good luck.
10/16/2020 12:13:43 AM • Uniden TRU9585... • Answered on Oct 16, 2020
TRU9585. 'fone blinks as if unheard msg, but there aren't any unheard msgs. How to stop blinking.
You have unheard messages on the voicemail service provided by your telephone company. This service records messages when someone calls while you're already on a call. Contact your telephone company for instructions on accessing their voicemail service.
8/15/2014 6:02:54 PM • Uniden TRU9585... • Answered on Aug 15, 2014
0answers
Lnstruction manual for tru9585 5.8 cordless phone
Certainly. You can download and print the manual here:
http://www.uniden.com/pdf/TRU9585om.pdf
If this response helped, please take a moment to give me a rating -- "Very Helpful" would be greatly appreciated.
11/23/2009 10:15:49 PM • Uniden TRU9585... • Answered on Nov 23, 2009
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
1/17/2009 4:35:59 PM • Uniden TRU9585... • Answered on Jan 17, 2009
Uniden BCD436hp - messed up my settings. Is there a way to get back the settings that were set by the company, when i purchased? Thanks!
If you can access the menu system, try Settings > Restore Options > Clear User Data > Full Reset. A quick step to do this, Press and hold 2, 9, and Dept when you power on the scanner. In the Clear User Data menu, there is also a Reset User Settings. This keeps the Favorites list. See page 31 of the user manual available at the Uniden support page: https://www.uniden.info/download/index.cfm?s=bcd436 . The current link to the English version of the manual is https://www.uniden.info/download/ompdf/BCD436HPom.pdf . I hope this helps. Cindy Wells
7/29/2021 4:16:44 PM • Uniden Lands... • Answered on Jul 29, 2021
How do I UNBLOCK a number from my Uniden Dect 6.0
ASK GOOGLE
4/16/2021 4:09:21 PM • Uniden Lands... • Answered on Apr 16, 2021
How do I remove phone number blocks from my Uniden 6.0
Unfortunately there is no simply delete all option So here's what you need to do , ( has uniden phone landline) Menu - down arrow - call blocking - menu key - view number - menu key - delete .. You'll need to do this for each number ... I haven't found a more easier way to do, I assigned a name to all the numbers like bogus 1 or scam 1 https://www.google.com/search?q=uniden+6.0+remove+blocked+contacts ..
4/16/2021 3:39:43 PM • Uniden Lands... • Answered on Apr 16, 2021
I have a uniden cordless phone. Recently I changed the battery of the cordless unit but still the range of the phone has reduced drastically. It works properly only when it is near to the base unit.
The range of a handset can be affected by many things. Try some of the simple, (and free), fixes first. Where is the base unit? Is it near other technology like a TV, wiFi hub or even things like a microwave. Is it near a window or an outside wall? Try moving it to a position nearer the centre of the house so the base unit covers more signal area. How old is the handset and base? Old phones and bases do get weaker as they get older. Are there solid, (brick), walls between you and the base unit when your using the handset? Thicker, denser building material blocks out some or all of the signal from the handset.
3/12/2021 10:07:08 AM • Uniden Lands... • Answered on Mar 12, 2021
I have a Uniden model D1780. I have 8 handsets.I have registered 6 including base headset. I try to register either one of the 2 remaining headsets say Registering then it say Registration Failed.
I had this exact problem on a D1780 and solved it by un-registering all of the handsets and then re-registering them. Before I did that it would only allow six phones to be registered at a time.
3/8/2021 1:54:30 AM • Uniden Lands... • Answered on Mar 08, 2021
Where is the set/ start button on Uniden AS-7401 phone? Mine doesn't have English letters.I tried all buttons with no result.Is it possibble to reset the phone somehow, and than begin setting?
It looks like the Set/Start button might be the right arrow button from the arrow keys to the right of memory buttons. It's possible that it is between the right and down arrows, based on where the manual shows "Setting Finished Exit from Operation". See the English version of the manual available here: https://www.ustel.com.hk/manual/Uniden/manual_AS7401_EN.pdf . I hope this helps. Cindy Wells
2/23/2021 7:24:28 PM • Uniden Lands... • Answered on Feb 23, 2021
How can I identify the model number of my uniden cordless phone. It has DECT 6.0 on it.
There should be a label on the base unit with the model information.
1/9/2021 11:52:37 PM • Uniden Lands... • Answered on Jan 09, 2021
Uniden D1780. How can I use intcom?
1/9/2021 10:56:41 PM • Uniden Lands... • Answered on Jan 09, 2021
Uniden TRU9585 Cordless Phone Logo
Popular Tags
24 questions posted
Top Uniden Lands Phones Experts
k24674
Ekse
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
handset out range message
  • Lands Phones
