20 Most Recent Humminbird XNT Transducers XNT 9 20 T Mounting Unit Questions & Answers
Hi I live in NZ
Don,
We would recommend that you replace the transducer (if you want to keep the transducer inside the hull you may use the
XP 9 20 T with temperature and you can use epoxy to mount the transducer) If you want to keep in the compartment you have created you may want to just put water in the compartment with the transducer so its not shooting through the air.
If you have any other questions please email customer service at [email protected]
Thank you,
Deborah
Humminbird Customer Service
1/12/2011 9:17:53 PM • Humminbird XNT... • Answered on Jan 12, 2011
My Matrix X25 used to
My unit, a 365i combo, uses the same transducer, I experienced the exact same problem last week, my unit is still under warranty, I sent the unit for repair and just got confirmation that my transducer went bad. The bad news is that the transducer is back order and has been for many weeks, this is an indication of probably a weak design. I have read similar reports on other forums.
Good luck
9/3/2010 2:40:55 PM • Humminbird XNT... • Answered on Sep 03, 2010
Need the best way to mount transducer to hull
www.sternmate.com
4/19/2009 12:20:26 AM • Humminbird XNT... • Answered on Apr 19, 2009
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
3/16/2009 9:16:46 PM • Humminbird XNT... • Answered on Mar 16, 2009
0answers
Black screen
Be the first to answer 8/12/2017 6:33:03 AM • Humminbird GPS • Posted on Aug 12, 2017Be the first to answer
Portable Humminbird 565
I've got the 565 and everything will be working fine and then the depth finder or bottom of the lake goes to 6ft. Have to shut it off for an hour and it works for a wile but it always goes back to doing it anything I can do? Thanks Jeff
6/8/2013 4:31:12 PM • Humminbird GPS • Answered on Jun 08, 2013
2answers
Need to locate and print
print users manual for Humminbird Pironha Max 160 Fish go to this link http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
9/7/2012 2:30:06 PM • Humminbird GPS • Answered on Sep 07, 2012
0answers
Humminbird XNT Transducers XNT 9 20 T  Mounting Unit Logo
7 questions posted
Top Humminbird GPS Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
View Most Popular
Humminbird GPS
  • Humminbird GPS
Most Popular Question
matrix x25 used
  • GPS
