20 Most Recent
Desa International TD104 Patio Heater Questions & Answers
Desa TD 104 Patio Gas heater
Sounds like you may not be getting enough gas up to the main burner. Bugs, such as spiders, love to make homes out of the main supply lines. Does your pilot light burn blue, and strong? If not, it may need to be cleared of the obstruction. Also, when opening the the gas tank valve, are you opening it slowly?
4/13/2012 9:49:49 PM •
Desa...
Answered
on Apr 13, 2012
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
2/19/2018 12:59:43 PM •
Desa...
Answered
on Feb 19, 2018
I HAVE A DESA MODEL T36 NRA
I have same model, went to all parts.com and ordered pilot assembly for 105$ , has all in one kit.
Part # 108084-02 easy instal
Good luck
9/24/2013 8:56:59 PM •
Desa...
Answered
on Sep 24, 2013
Comfortglow modle cgn30tb @cgn30tlb,,,,light it and it burns good for 5 or 10 min,,,starts hissing and then poof it goes out..has been working fine up till now,,,,
