20 Most Recent Weber Summit E-420 Gas Grill Questions & Answers
That's not unusual at all. Nor, is it a design flaw. The are are air vents all along the back of the grill head that allows rain to get in. Especially, blowing rain. The best solution is to either bring the grill into the garage when it's not in use OR if you don't have a garage, invest a few $$ in a good quality grill cover. Not some cheap $9.99 special. Either one, will solve the water problem, as well as keep the tree drippings and bird droppings off the grill.
Weber Summit... | Answered on Apr 19, 2011
Open Stovetop
On most stoves, the air shutter is just behind the burner gas valve. It is a sliding plate or tube that covers the burner air vent. Loosen the set screw that keeps the shutter from moving. Turn the burner on fully and slowly open the shutter until the flame turns blue
https://homeguides.sfgate.com/causes-burner-flame-gas-stove-yellow-82498.html
Weber Grilling | Answered on May 10, 2020
SAND OFF RUST AND PAINT WITH GRILL PAINT
Weber Grilling | Answered on Apr 02, 2020
Google the make and model for a parts list , We do not have a price on here
Weber Grilling | Answered on Oct 10, 2019
How to Reset the Propane Regulator for a Gas Grill
  1. Open the cover lid on your gas barbecue and turn all burner dials to the OFF position. ...
  2. Disconnect the regulator from the propane tank shutoff valve by twisting the knurled mounting knob in a counterclockwise direction. ...
  3. Open the burner control knobs on the grill fully.
More items...
Dec 22, 2017
How to Reset the Propane Regulator for a Gas Grill ' Hunker
https://www.hunker.com/13408162/how-to-reset-the-propane-regulator-for-a-gas-grill
Make sure you open the valve very slowly the first time.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=frtJXYTdF7CKgge2-pvQCg&q=bbq+regulator+reset&oq=bbq+regulator
Weber Grilling | Answered on Aug 06, 2019
It is malfunctioning -- be careful not to let anyone get hurt by a malfunctioning gas grill!
Weber Grilling | Answered on Jun 25, 2019
Sounds like your propane tank is empty. Go get a refill!
dicking around with parts from the manufacturer is expensive, time consuming and will prove frustrating since even if you get it to work it will fail again in no time. Instead, consider getting yourself one of those extended butane lighters at the grocery store. The ones with flexible lighter shafts work best in most applications.
Try twisting the igniter button counter clockwise
Weber Grilling | Answered on Jun 04, 2019
Yes you can and it is a great way to keep them clean. If you have the cast iron grate, you will need to oil them or they will rust.
Weber Grilling | Answered on May 13, 2019
wire brush it off and move on. i doubt weber would do anything if its out of warranty
Weber Grilling | Answered on Apr 27, 2019
Weber Summit E-420 Gas Grill Logo
1 questions posted
Top Weber Grilling Experts
Paul Carew
Marvin
Marvin
Zhareese
Are you a Weber Grilling Expert? Answer questions, earn points and help others
View Most Popular
Weber Grilling
  • Weber Grilling
Most Popular Question
weber e 420
  • Grilling
