20 Most Recent Nextar I4-BC GPS Receiver Questions & Answers
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
Nextar I4-BC GPS... | Answered on May 29, 2014
I have a nextar 14-bc and I was having similar problem and I found that the power in jack had a broken solder joint and when I thought it was charging it was not. I would not turn on until I discovered the broken solder joint inside on the power jack. I resoldered it and after it charged up it was up and working again. You might check on that.
Nextar I4-BC GPS... | Answered on Dec 23, 2011
Try manually rebooting by holding off button for few seconds and doing the same as it reboots up until u let go of the on button.
Nextar I4-BC GPS... | Answered on May 08, 2011
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Nextar I4-BC GPS... | Answered on Dec 03, 2010
Connect your device to a computer using the usb cord. If your getting songs from the internet try to select songs from your source and download it first to your pc's hard drive. Once all the selected songs are downloaded, access the files and press ctrl A to select all the songs and right click the mouse. In the drop down command select SEND TO and choose the location of the removable disk that represents your device. Wait until the downloading is finished. If you have any other concerns just write a comments on this topic. Thank you.
Nextar I4-BC GPS... | Answered on Nov 24, 2010
The battery has come to the end of its service life, you will need to replace the battery. Contact Nextar at www.nextar.com for information.
Nextar I4-BC GPS... | Answered on Jun 17, 2010
There are updates for a 14-BC is hat what you are looking for? If so follow the link. Hope this works!!!
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=I4-BC&subpr=&categ=
Nextar I4-BC GPS... | Answered on Sep 20, 2009
PDF] I4-BC Hardware Manual.pdf 2345k - Adobe PDF - View as html Global Positioning System ("GPS") hardware, operating software or other aspects of this ... outlet again to reset the player. If the problems still exist, ...www.nextar.com/images/Product/I4-BC Hardware Manual.pdf
Nextar I4-BC GPS... | Answered on Aug 16, 2009
That is always the case.
people have been advised to be careful of downloading upgrades. Especially ones from an unknown source.
All you need do is consult the manufacturer page and get details on how to contact them for repairs and reformatting or flashing of the device.
Don't let anybody deceive you about this.
Good luck friend. And don't forget to rate this solution and advice.
Nextar I4-BC GPS... | Answered on Aug 08, 2009
You will have to check at the factory website for updates, if any are available they will be there.
Nextar GPS | Answered on Jul 31, 2018
Nextar I4-BC GPS Receiver Logo
Popular Tags
24 questions posted
Top Nextar GPS Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
View Most Popular
Nextar GPS
  • Nextar GPS
Most Popular Question
no voice when unmuted
  • GPS
