20 Most Recent Magellan Maestro 5310 Car GPS Receiver Questions & Answers
My Magellan Maestro 5310 is
Hello There, I have a Magellan myself, besides me knowing some things or two about GPS'S
Give this a try, seems to work for me and others most the time.
Try this for me to see if this works: Let me know. It needs to be rebooted. Turn off, by holding off button down. Then once it is completely off, then turn it on, BUT when you go to turn it on, keep on button depressed, all the way until it turns on and then some for about 15 seconds, now you just rebooted system. Let me know, if does work, please click on the thumbs up to showed your a happy customer. Thanks Mike
8/31/2018 12:00:55 AM • Magellan Maestro... • Answered on Aug 31, 2018
Has never had maps updated. Can I get any or do I just have to buy a new GPS?
You will need to purchase map updates from the magellan website to be able to update your map magellangps.com
6/6/2015 7:46:18 PM • Magellan Maestro... • Answered on Jun 06, 2015
Why is my magellan 5310 frozen?
can it see the clear sky above for starters
2/13/2015 4:27:48 AM • Magellan Maestro... • Answered on Feb 13, 2015
Wrong current location
its not tracking satellite properly mine does the same thing am investigating
3/24/2014 1:19:52 PM • Magellan Maestro... • Answered on Mar 24, 2014
I wanted to erase all the maps so i gave a format and everything erase. what could i do?
best suggestion is contact Magellan about this.....
11/5/2012 5:01:19 PM • Magellan Maestro... • Answered on Nov 05, 2012
Sound is really low
either the sound level is adjusted too low in the unit or you have a audio problem in the unit---get the owner manual---My Magellan I had to lower the sound just a little as for me it was a distraction being too loud.
10/24/2012 5:09:17 PM • Magellan Maestro... • Answered on Oct 24, 2012
3answers
I want to change the battery in my Magellan
use your finger nail and press and slide it along the seem where the front and back meet..there are at least 2 snaps on each side of the gps...start opposite the power port side or you can break it off..let that side for last!
bill
2/10/2012 4:26:21 AM • Magellan Maestro... • Answered on Feb 10, 2012
User manual for magellan maestro 5310 gps
Hello,The user manual can be downloaded here:Maestro 5310 - Owners Manual
1/12/2012 7:30:01 PM • Magellan Maestro... • Answered on Jan 12, 2012
Power pin is broken cannot charge gps their is no
go to ebay and type in "magellan power port" then ask the seller/s sorry i am not allowed to give you a direct link...per fixya rulesPLEASE SUPPORT OUR TROOPS
10/7/2011 10:36:25 PM • Magellan Maestro... • Answered on Oct 07, 2011
Im not able to turn my unit off or get any
Please try this solution:
  • Try to locate the reset button then use a pin that will fit to the hole the press and hold it for 10 seconds.
  • Then after that release it then it will turn off and then turn on again. Then try to input directions and check if it will work again.
  • And if there is a firmware update please do download it at www.magellan,com.
If you have any additional questions feel free to reply to this solution. Have a great day. I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
9/13/2011 3:42:41 AM • Magellan Maestro... • Answered on Sep 13, 2011
Unit has stopped working. Have tried charging in
Thank you for contacting fixya.com.
Try a hard reset .Turn the GPS on then locate the little pin hole on the side, using a paper clip, push reset. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on. If that does not work try to update your GPS from the bellow link:-
http://www.magellangps.com/
If the problem still persists you need to contact the customer support for the unit replacement Please get back to us if you have further query else please accept the suggestion.
6/30/2011 11:48:23 AM • Magellan Maestro... • Answered on Jun 30, 2011
My magellan mastro was left for months with no
If you're using it in a car with a car charger then you should be able to plug it in and use it straight away and the battery will charge while its being used.
If you're charging it to use while you're on the move without it being plugged in then it will take 6 hours to fully charge which should give you 2 to 3 hours of use.
6/15/2011 6:50:38 PM • Magellan Maestro... • Answered on Jun 15, 2011
The power conection port on my gps is loose inside
hi scotty01
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
3/2/2011 9:57:49 AM • Magellan Maestro... • Answered on Mar 02, 2011
Magellan Maestro 5310 Car GPS Receiver Logo
62 questions posted
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
View Most Popular
Maestro Magellan
  • Maestro Magellan
Most Popular Question
power pin broken cannot charge gps no
  • GPS
