20 Most Recent
LG LS092CE Split System Air Conditioner Questions & Answers
Split ac not cooling the room
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
LG LS092CE Split...
Answered
on Jun 01, 2013
My lg ac colling good but after 15 to 20 minutes run of all systems and display show CH05
Here is an answer from official LG site:
The CH05 error message means you have an indoor / outdoor unit communication error. It can be caused by any of the following issues:
- No power on indoor unit
- Indoor/outdoor unit power connection error / communication line not installed
- Communication error caused by external noise
- Indoor/outdoor unit communication circuit parts burned.
In my opinion if it works for some time and then shows the error it may be communication error caused by external noise.
You should contact the trained technician to deal with that problem.
LG Heating &...
Answered
on Sep 24, 2020
LG filter light stays on
I just checked the manual for mine. Press the temp up/temp down buttons together to reset the light. It will come on again after 250 hrs of operation to remind you to clean your filter.
LG Heating &...
Answered
on Jul 21, 2020
Lg window unit a/c won’t turn on after sitting through the winter, what could be the problem
There are many things of which could have happened. For the best and (hopefully) quickest results, contact your local technician specialist or the company of whom built your window unit. If this does not work, try looking at the help and FAQ pages on multiple business's sites to see how others solved similar problems as well. If you prefer to see it for yourself, try searching on YouTube of how to fix your situation at home. Hope this helps!
LG Heating &...
Answered
on May 29, 2020
Error code LG CH 05,how to fix this
LG Heating &...
Answered
on Apr 21, 2020
My LG air conditioner is saying water fl what is that and where can I find it? I cannot find the book.
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain.
Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service.
Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps.
LG Heating &...
Answered
on Apr 10, 2020
