20 Most Recent LG LA125HV Split System Air Conditioner Questions & Answers
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
LG LA125HV Split... | Answered on Apr 29, 2010
https://slotjk.com/ check more for your solution
LG Heating &... | Answered on Oct 24, 2020
Check for proper condensate drainage. Make sure the drain pan and drain tube isn't clogged with debris and check for mold inside the unit. Check that the blower wheel is clean as well.
LG Heating &... | Answered on Sep 29, 2020
Here is an answer from official LG site:
The CH05 error message means you have an indoor / outdoor unit communication error. It can be caused by any of the following issues:
  • No power on indoor unit
  • Indoor/outdoor unit power connection error / communication line not installed
  • Communication error caused by external noise
  • Indoor/outdoor unit communication circuit parts burned.
In my opinion if it works for some time and then shows the error it may be communication error caused by external noise.
You should contact the trained technician to deal with that problem.
LG Heating &... | Answered on Sep 24, 2020
There should be a drain pipe at the side or bottom of unit to run a drain line. Locate drain and clean it out .
LG Heating &... | Answered on Sep 20, 2020
I just checked the manual for mine. Press the temp up/temp down buttons together to reset the light. It will come on again after 250 hrs of operation to remind you to clean your filter.
LG Heating &... | Answered on Jul 21, 2020
Here is the link to LG web page and error code
But it looks like it need to be professionally repaired
https://www.lg.com/us/support/product-help/CT10000014-1432829295501-display-shows-%22hi%22
LG Heating &... | Answered on Jul 14, 2020
There are many things of which could have happened. For the best and (hopefully) quickest results, contact your local technician specialist or the company of whom built your window unit. If this does not work, try looking at the help and FAQ pages on multiple business's sites to see how others solved similar problems as well. If you prefer to see it for yourself, try searching on YouTube of how to fix your situation at home. Hope this helps!
LG Heating &... | Answered on May 29, 2020
It appears to be an error 22. According to the LG bible, it means an overcurrent protection has activated. In most cases, unplug the machine or switch off from power supply for at least 15 minutes, it should reset the main control board. If this doesn't work , it may have damaged the board. Alternatively, if your machine is on 3 phase, check that all fuses / circuit breakers in your meter box are OK and switched on. You may have a weak or disconnected power supply.
LG Heating &... | Answered on May 07, 2020
Same happened with my AC. I read it online to be an issue with low voltage. I just unplugged the power cord and replugged it again, and it worked.
LG Heating &... | Answered on Apr 25, 2020
LG Heating &... | Answered on Apr 21, 2020
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain.
Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service.
Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps.
LG Heating &... | Answered on Apr 10, 2020
https://www.youtube.com/watch?v=sYNN1Rvc7r0
https://removeandreplace.com/2017/06/06/lg-split-system-air-conditioner-error-codes-troubleshooting-maintenance/
LG Heating &... | Answered on Mar 23, 2020
LG Split System Air Conditioner Error code = C6 or CH06 LG AC Fault Definition = Excessive current at inverter DC power circuit - DC Peak Power
Flashing Light = 6
Display = Indoor Outdoor
Indoor Operation = SHUTDOWN
There are several things that can cause this,, first step is to check all wiring connections, but this can be pointing to a more major issue, the AC to DC transformer,,
It is a experienced tech kinda job
LG Heating &... | Answered on Jan 09, 2020
LG LA125HV Split System Air Conditioner Logo
1 questions posted
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
2 la125hv w 1 condensing 1 air handler
  • Heating & Cooling
