20 Most Recent Samson Audio C01upak C01u Microphone and Podcast Pack Questions & Answers
No. From their website...
Note: Samson SoftPre is not compatible with Windows Vista however the C01U, C03U and Q1U are all Plug-and-Play compatible with Windows Vista.
Samson Audio... | Answered on Jul 04, 2016
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Samson Audio... | Answered on Aug 03, 2014
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Samson Audio... | Answered on Dec 01, 2010
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Samson Audio... | Answered on Sep 22, 2009
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Samson Audio... | Answered on Feb 26, 2009
Check if you selected the mic as the default audio input on the respective programs.
Samson Audio... | Answered on Aug 07, 2008
You can safely connect your powered monitor speaker to either the monitor output jacks or the tape output RCA jacks on your XP510. In addition, you may download the owner's manual here:
https://www.manualslib.com/download/515708/Samson-Expedition-Xp510.html
Samson Music | Answered on Oct 31, 2018
Which amplifier specifically?
Samson Music | Answered on May 04, 2014
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
Samson Music | Answered on Mar 17, 2010
https://blog.caristaapp.com/mlb-evo-testers-wanted-q7-q8-a8-827e78827e0f
Music | Answered Yesterday
Samson Audio C01upak C01u Microphone and Podcast Pack Logo
10 questions posted
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
View Most Popular
Samson Music
  • Samson Music
Most Popular Question
use vista samson c01u usb condenser mike
  • Music
