20 Most Recent
Samson Audio C03upak Co3u Microphone with Podcast Pak Questions & Answers
Is the position of my CO3 Samson Mic. in the right place
exactly how did you place your mic? Because in the picture you are showing there are placed two or three mics. The best sound quality does not always depend on the up or down position of your mic. It has a lot to with the acoustics of the room you are recording in, the distance you vocalist is standing and even of you use a windscreen or a reflection wall. The best advice is clap you hands a few times in your room and make sure the clap turns dead. If you clap go's silently dead, without hitting any walls or windows that reflect the sound, than you will have a good position to record.
Samson Audio...
Answered
on Mar 10, 2010
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Samson Audio...
Answered
on Jan 29, 2010
When i play my acoustic guitat through the Samson
This could be caused by a faulty cable or a fault on one of the ends of the cable. Open each side of the cable, the jack should screw off. Once it is open check to make sure that both of the wires are connected firmly. If they're not, you will need to solder them on properly and if they are, then this is not the problem.
This could be a due to the settings on your speaker or the mixer you are using. On the speaker, check that the low's mid's and high's are set correctly and then check the mixer to see if the line in from the guitar is set correctly and check that the line out is set correctly. If all of this is fine then it could be due to your guitar DI.
Check that your DI is set correctly,e.g. Make sure that the DI is not set to run a link between both lines, it should be set as single.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Samson Audio...
Answered
on Jan 06, 2010
Samson CO3U USB mic pattern selection switch broken
I have not used that particular mic, but have a AKG 414 which offers the same three patterns and there are three distinct and separate settings on the switch. Maybe take it back into the store where you bought it and ask for clarification there? Hope this was helpful. Peace
Samson Audio...
Answered
on Jan 08, 2009
Samson MDR8 blowing internal power supply fuses.
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
Samson Music
Answered
on Mar 17, 2010
