20 Most Recent Epiphone Les Paul 100 Electric Guitar Questions & Answers
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Epiphone Les... | Answered on Jun 10, 2019
Hi Larry:
Just Google this
and you'll get all the info that any of us can.
Cheers
Epiphone Les... | Answered on Oct 13, 2015
The company from where you got the pickups would have the schematic. What pickup are they.
When there are 4 wires it usually to split the coils in the individual pickups
Epiphone Les... | Answered on Apr 03, 2015
Vintage numbers from 1932 to 1970 are now supported. Serial numbers from 70' and 80's era Epiphone guitars made in Japan are not supported. The reason for this is that there is no reliable documentation from this time period. This Module has been updated to work with the newer serial number formats.
Supported Brands
*Pot Code Reader*EpiphoneFenderGibsonIbanezYamaha
guitar was made inĀ
Korea
November c.2010
http://www.guitardaterproject.org/epiphone.aspx
hope this helps?
Epiphone Les... | Answered on Mar 02, 2015
Contact Gibson Customer Service at 1 (800) 444-2766
Epiphone Les... | Answered on Jan 02, 2015
If you widen the space between strings your low E and high E become closer to the edge.
Epiphone Les... | Answered on Nov 26, 2014
Your guitar was made in
Indonesia
May 2009
Production Number: 1332
Epiphone Les... | Answered on Oct 11, 2014
That's a CTS pot. i suspect it's been changed from the original one.
MC = China
21 = some list this as the year but...1921?!? Not likely
07 = most likely the year 2007
0612 = manufacturing ranking (your axe was number 612 built that year).
Epiphone Les... | Answered on Jul 31, 2014
Are you trying to price this out or are you looking for more info about the instrument?
Epiphone Les... | Answered on Jun 05, 2014
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Epiphone Les... | Answered on Mar 14, 2013
Search google for "emg pickup wiring" and up it pops!!!
Epiphone Les... | Answered on Sep 14, 2011
If it is a coax with a wire in the center and a shield outside, the wire will attach to the contact that touches the tip of your plug you insert. The shield will attaach to the part that touches the sleeve of you plug. inspect the jack carefully as they can be foolers. When stripping the insulation back un-braid the shield a little to be able to solder it to the jack. Use a pair of needlenose and a helper to keep soldering heat from going up the braid and melting the insulation of the internal wire. Test unit before putting cover on.
Epiphone Les... | Answered on Apr 25, 2011
Go to this site and find a guitar with the same configuration of controsl, pickups, etc as yours to see typical diagram. With CAREFUL inspection and good lighting often you can see where the wire broke from.
Epiphone Les... | Answered on Apr 16, 2011
First check the cable. If that works fine on another instrument then i would check the input jack next. Also try turning the volume knobs. You may have a dead spot on the potentiometer.
Epiphone Les... | Answered on Mar 21, 2011
Mine came from factory with the first three (ead) facing the higher side outside (away from the fret board) and the other ones (gbe) to the inside.
Epiphone Les... | Answered on Feb 28, 2011
The cable has a broken wire. If it's the type cable which allows unscrewing the jack, take it apart and look for a loose / broken connection. Repair would be to solder it back. If the jacks on the cord are the molded type, the most practical solution is to replace it.
Charlie
Epiphone Les... | Answered on Feb 21, 2011
Epiphone Les Paul 100 Electric Guitar Logo
42 questions posted
Top Epiphone Music Experts
Robert Graf
Harrie
Marvin
Marvin
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
serial no sj03031568
  • Music
