20 Most Recent Epson PowerLite 77c Projector Questions & Answers
you need an adapter cable: connect-macbook-epson-77c-projector-rd53xsmc3ry4fozipcd12amw-4-0.jpg connect-macbook-epson-77c-projector-rd53xsmc3ry4fozipcd12amw-4-2.jpg connect-macbook-epson-77c-projector-rd53xsmc3ry4fozipcd12amw-4-5.jpg
Epson PowerLite... | Answered on Dec 13, 2014
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Epson PowerLite... | Answered on Jan 13, 2014
was there smoke, or the smell of smoke/burning. Its more than likely a compasitor, and unless you know how to electrical trouble shoot, and sodlier then you will need a new one. We call if magic smoke in the electrical industry, and its never good.
good luck
Epson PowerLite... | Answered on Apr 30, 2013
VCRs typically do not have RGB outputs. If you are using the VCR as a tuner for your projector, then be sure you have selected the VCR/TV button to VCR then your VCR will be the tuner. If you have it set to TV then the signal is passed through the VCR by your coax to the TV and the TV is the tuner but the VCR is now only outputting Channel 3.
Epson PowerLite... | Answered on Mar 10, 2011
Simply pushing the Help Button, and then selecting, Problem with the Image, and then setting the Computer to Auto fixed the problem! Thanks!
Epson PowerLite... | Answered on Apr 13, 2010
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Epson PowerLite... | Answered on Mar 16, 2010
Hello :
try this please :
http://www.ehow.com/how_4797587_hook-up-laptop-projector.html
good luck .
rate if useful please !
Epson PowerLite... | Answered on Mar 01, 2010
Easy Steps to Fix Epson Printer Error Code 0xF1. This technical issue might due to software or hardware problems with your printer or computer. The main step that you can perform is unplug the printer from the main socket, remove the printer cartridge and then reattach it
See An Other Video
https://www.youtube.com/watch?v=L2UHrDlEgwc
Epson Office... | Answered Yesterday
Easy Troubleshoot for Epson Printer Error 0xf1
Remove it and try again to print after restarting your system and printer. Try to restart your printer with simply print button. If the earlier process failed, try a new method to solve error code 0xf1. Wiggle your printhead.May 11, 2019 techsupportexpert.com > how-to-fix-epson-printer-error-code-0xf1
What is Epson Printer Error Code 0xf1? The Epson Printer Error Code 0xf1 is a critical error which bars the printer to execute the command sent by the computer. Generally, this error is caused by corrupt registry entry in your computer. In this error, your printer will not be able to read from the left to right side when you turn it on.
How to Fix Epson Printer Error Code 0xf1? 1.) The most basic and easy to resolve this error is to unplug the power cord of the printer and remove the cartridge. Now install the cartridge again and plug the cord and switch on. If the error code 0xf1 is due to the hardware, then this step will fix it.
2.) In case your system is affected with virus or malware, then also you can face the same error. Due to the malware attack, any program can install or uninstall without permission as well as notification, your hardware or RAM can decline to execute any command and there may be fragmented files or any other issues which lead the Epson printer to error code 0xf1. These multiple installation, un-installations and modifications cause system conflicts, registry errors and ActiveX errors.
3.) When you uninstall any file from your computer, some files remain in the system. And all of these files disturb the functionalities including the action of the printer. You need to remove the leftover files to get a hassle free printing experience.
4.) If your computer lacks the maintenance, then it tends to freeze or crash. You need to shun this problem. Along with good maintenance, you need to download Epson Error Code 0xf1 Repair Tool. This tool will help you to clean the junk files, decrease the startup time, restore the lost memory, defragmentation of the hard drive and most importantly remove spyware, malware or any other threats. You can have the limited features in its free version, but if you want all the advantages, then you have to buy the full version.
These tips will help you to fix Epson Printer Error Code 0xf1 easily or if you need any other technical help then you can contact certified Epson printer customer care team for instant support.
Epson Office... | Answered 3 days ago
ASK EPSON OR GOOGLE WE DO NOT KNOW
Epson Office... | Answered on Jan 24, 2020
Epson PowerLite 77c Projector Logo
19 questions posted
Top Epson Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
projected image pinkish purple tint
  • Office Equipment & Supplies
