20 Most Recent Select Brands SC-25 2.5-Quart Questions & Answers
Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
http://busycooks.about.com/library/print02/ncrockpot101.htm
Select Brands... | Answered on Dec 09, 2011
NO! Never put water in the base
Select Brands... | Answered on Oct 03, 2010
Contact the manufacturer. They have replacement parts.
Select Brands... | Answered on Jan 05, 2009
The auto mode means that the cooker will start off at high and then will switch to low after an alloted amount of time.
Select Brands... | Answered on Apr 16, 2008
I had no power on my cepc800. Since parts are not available I had my husband tear it apart. If you are not electrically inclined don't try it....the problem in mine was a high temp resistor, which was bad. The problem was solved with a $2.50 resistor from our local electronics store.
Select Brands... | Answered on Apr 27, 2014
I couldn't find instructions on their website, but they do have an email contact form here:
http://www.prestige.co.uk/customer-assistance
Good luck, and I hope this helps!
Select Brands... | Answered on Jul 01, 2011
I need to find a manual for the Panasonic slow cooker model NF-M15W
Select Brands... | Answered on Jun 19, 2011
Hi Jerry,
The ladies are right.
The appliance is called a steam table, and it operates on the same principle as a double-boiler. The design uses water as a thermal buffer between the heating element and the food, and ensures that the food is kept at food-safe serving temperature (varies by food, but typically over 140F, sometimes over 170F) but won't let the food get hotter than 212F so it doesn't burn or overcook the food.
If it's splattering boiling water, then it's overfilled and you should reduce the amount of water, but only by a little bit. A steam table should NEVER be allowed to run completely dry.
As for the steam getting you when you take out a pan -- that's true, and you do have to be very careful when you remove pans from a steam table.
Select Brands... | Answered on Apr 03, 2010
https://www.google.com/search?q=Is+there+a+local+repair+service+near+01748+for+my+All+Clad+Crockpot%3F&rlz=1C1OKWM_enUS816US816&oq=Is+there+a+local+repair+service+near+01748+for+my+All+Clad+Crockpot%3F&aqs=chrome..69i57.555j0j4&sourceid=chrome&ie=UTF-8
Crock Pots &... | Answered 12 hours ago
Fixya does not sell parts.
Crock Pots &... | Answered on Aug 12, 2020
Select Brands SC-25 2.5-Quart Logo
9 questions posted
Top Select Brands Crock Pots & Slow Cookers Experts
ray gallant
Andrew Taylor
Andrew Taylor
Marvin
Marvin
Are you a Select Brands Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
View Most Popular
  • Select Brands Crock Pots & Slow Cookers
Most Popular Question
add water in
  • Crock Pots & Slow Cookers
