20 Most Recent Viking VUWC141 Wine Cooler Questions & Answers
what is the model number is then we can get started then okay??
Viking VUWC141... | Answered on Sep 12, 2013
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Viking VUWC141... | Answered on Jun 04, 2010
There are several issues that need to be checked. What mode is the deffroster set to? There are several modes to check. There is a heater coil under the pan to assist in evaporating the water from the condensation tray. If you are in a high humidity area the condensation could be from that. I have attached the service manual for that unit to this post. http://www.uncleharrywizard.com/NephewClub/wizardfrig/viking/viking-bottom-freezers/smr-0007---bottom-mount-536.pdf
Viking... | Answered on Sep 14, 2020
Possibly blocked drain from evaporator. When fridge goes into reverse cycle ice melts on evaporator and drains to a dish on the motor housing, this evaporates when motor runs. May have a crack in this dish or drain pipe has a hole or not draining into dish.
Viking... | Answered on Oct 03, 2019
I have a D3 Viking fridge, freezer that has coils freezing up. It seems to be working good, but leaks water on floor. Cleaned out vent coils underneath unit..
Viking... | Answered on Jul 02, 2019
It’s no longer available and if you want to spend $160 for shelf you can found somebody make you one for less than that
Viking... | Answered on May 19, 2019
It's likely screwed down. You will either see some screws at the front top of the refrigerator that are screwed into the countertop above or an anti tip bracket in the rear that you can't see. If you don't see any screws attaching it to the countertop, try shoving is back towards the wall and the tipping it forward. That should remove it from the anti tip bracket, if installed.
Viking... | Answered on May 03, 2019
this sounds like theres a mistake with the water hose output
besides check your filter
and follow the water hose route to solve this problem
dont forget to comment
Viking... | Answered on Apr 30, 2019
Your question seems strange, I know it is April fools day but you say it is brand new but it is three years old. You say it has been clicking for two years but then you say two days. If it has been clicking for two years but is still working I would accept this as it's normal operation. The clicking could simply be the switching off and on of the pump.
Viking... | Answered on Apr 01, 2019
Try two different things: 1. Move (if possible) your fridge out from he back wall about 2 inches. 2. Vacuum the vent areas and underneath coils. Sounds like the flow of air is not properly circulating.
3. Call the toll free watts line of the mfg. ask fot tech services and describe the problem...Be sure you have the complete Model # and Serial # in hand before speaking to anyone!
Viking... | Answered on Mar 27, 2019
I used the solid copper wire trick suggested by Ron - worked great. I also vacuumed out the coils at the top of the fridge behind the grill in case that was a contributing factor. No frost since!
I later learned that Viking has a retrofit part to address this issue:
http://www.allvikingparts.com/016774_000_SECONDARY_DRAIN_TROUGH_KIT_p/016774-000.htm
It’s designed to both ensure water reaches the drain hole, and that the drain remains unfrozen.
Viking... | Answered on Mar 09, 2019
Viking VUWC141 Wine Cooler Logo
5 questions posted
Top Viking Refrigerators Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Colin Stickland
Colin Stickland
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Refrigerators
Most Popular Question
viking wine cellar temperature near
  • Refrigerators
