20 Most Recent Viking VCSB483 Side by Side Refrigerator Questions & Answers
Fan keeps running
freezer fan runs when freezer calls for cooling ref fan runs when fridge calls for cooling condenser fan up top runs with compressor lower unit condensate fan runs with compressor fans should not be noisy control monitors temp and will give alarm if temp rise please contact viking as your fridge may have a safety recall on door hinges
10/18/2017 6:09:14 PM • Viking VCSB483... • Answered on Oct 18, 2017
How do I remove drain pan on Viking VCSB483 refrigerator freezer? It slides out almost all the way, but gets stuck on the right hand side and won't come out.
you have to remove the float that hangs from ceiling on rh side (depending on age) also if your tray has foil heater under it this has to be removed first (depending on age and service history)
10/18/2017 5:26:50 PM • Viking VCSB483... • Answered on Oct 18, 2017
2answers
Viking side by side refrig/coils are freezing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
11/26/2014 1:30:27 AM • Viking VCSB483... • Answered on Nov 26, 2014
0answers
0answers
0answers
0answers
Leaking
Be the first to answer 8/30/2012 11:03:15 PM • Viking VCSB483... • Posted on Aug 30, 2012Be the first to answer
Viking freezing evaporator coil
im not sure if still is the case.but there used to be a timer that shuts off the refridge so it self defrost. it is set to do this 1ce a day so the ice or frost does not build up.it is called a defrost timer. if it fails it will not shut down the fridge.most of them are near the front behind the grate.
12/29/2011 5:13:01 PM • Viking VCSB483... • Answered on Dec 29, 2011
My vegtable tray center bar has snapped from the
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
5/6/2011 2:55:45 AM • Viking VCSB483... • Answered on May 06, 2011
Viking refrigerator model VCSB483. Alarm
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3/18/2011 11:37:28 PM • Viking VCSB483... • Answered on Mar 18, 2011
How to I start the fridge
It should start automatically when plugged in. If it doesn't test the outlet to make sure it's providing power.
3/5/2011 1:34:08 AM • Viking VCSB483... • Answered on Mar 05, 2011
The freezer stops working every 4 days, the fan
You are not getting enough air flow. Make sure all dust bunnies are cleaned-off on your coils on the
back and underneather and clean any filter's.
2/8/2011 1:07:28 AM • Viking VCSB483... • Answered on Feb 08, 2011
How do you turn off the refrigerator so technician
There is no turn-off switch on a refrigerator, you have to unplug it from your outlet. The tech. will
know this.
2/8/2011 12:40:03 AM • Viking VCSB483... • Answered on Feb 08, 2011
2answers
It beeps randomly - the same beep when the door is
are you getting any display codes or warning lights?? It may just need the cond coil cleaned up top.
Find the switch that the door hits to shut off the lights. push it to see if the lights go out. It could be a bad lite switch
2/8/2011 12:03:01 AM • Viking VCSB483... • Answered on Feb 08, 2011
Freezer not getting colder than 34 degrees
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
1/11/2011 4:05:01 PM • Viking VCSB483... • Answered on Jan 11, 2011
Not cooling and door open light stays on. fan
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
dfncv
9/29/2010 9:24:47 PM • Viking VCSB483... • Answered on Sep 29, 2010
Vcsb483
if you remove the center part of the grill you will then find four 1/4" screws on the black back section remove them then loosen the bolts one on the right and left and the switch is going to be on the right side. The reason I am telling you to take off the whole grill vs just the center is that you are going to need to clean the condensor that is going to be on the left side at the top. IMPORTANT ONLY CLEAN THE CONDENSOR IN AN UP DOWN MOTION DO NOT GO ACROSS AS THIS WILL DAMAGE THE FINS.
Thank you and have a great day,
Sabastian
8/28/2009 12:48:24 PM • Viking VCSB483... • Answered on Aug 28, 2009
Viking VCSB483 Side by Side Refrigerator Logo
35 questions posted
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Ramirez
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Refrigerators
Most Popular Question
help
  • Refrigerators
