20 Most Recent Viking VGSC306-4B Gas Kitchen Range Questions & Answers
Viking gas broiler will not light. New ignitor.
yes bi metal inside valve is open did something metal fall on igniter or was valve direct wired or miss wired
1/2/2018 7:15:18 PM • Viking... • Answered on Jan 02, 2018
0answers
Various Problems
Be the first to answer 6/25/2017 8:03:03 PM • Viking... • Posted on Jun 25, 2017Be the first to answer
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
7/29/2015 10:53:46 AM • Viking... • Answered on Jul 29, 2015
Do I really need to replace the whole oven thermostat on my Viking if only the knob shaft broke off?
I would follow his recommendation. If it is not repaired correctly you will have temperature problems and it will hold the know in the right position.
4/29/2014 8:23:32 PM • Viking... • Answered on Apr 29, 2014
0answers
Install pb010186
Be the first to answer 3/4/2014 4:12:18 AM • Viking... • Posted on Mar 04, 2014Be the first to answer
Hotplate ignitor for VGCC5486G
Yes moisture stops the igniters working, use a hairdryer on the area around the igniter button, if you can get hot air in behind it. When it dries out it should continue to work.
12/19/2013 3:37:59 PM • Viking... • Answered on Dec 19, 2013
3answers
My Viking range top grates are dirty
viking advises using nothing but warm soapy water. grate polish works very good to bring that deep black shine to the grates again
10/11/2013 9:44:59 PM • Viking... • Answered on Oct 11, 2013
Viking oven won't heat
Igniters need to be replaced
5/30/2012 4:29:36 PM • Viking... • Answered on May 30, 2012
0answers
Vgsc3664qbu is converted to propane,
Hi.
If the smell is there even when oven is not on, then you have a leak. Check gas hose and pressure regulator (if installed).
If smell is there only when oven is on, then the problem is either the igniter or the orifice.
Ensure that the orifice has been changed with the one for propane.
Check the flame from orifice. The flame must be blue with an orange tip. If the flame is mostly orange, then the lp is not burning correctly. That usually happens when the orifice is defective or wrong. Ensure that the kit is installed correctly.
If the orifice is OK, the problem can be the igniter. If the igniter is not working well there will be some gas release when the igniter try to start.
Check if problem is with both broiler and baker. Ensure that both assemblies had been replaced correctly. Check first the kit assembly and the orifice for both. If you do not find anything, replace igniters and burners. Do not use the oven until the problem is fixed. If the oven have been converted recently there is a problem with conversion kit. The conversion must be rectified before you can safely use the oven.
Regards.
Ginko.
3/30/2011 8:42:35 PM • Viking... • Answered on Mar 30, 2011
I have a Viking VGCC
Hello, Welcome to FixYa. The way to replace those ignitors is through the oven itself and not the lower panel below the door. Of course the first step is to unplug the stove or turn off the breaker. Remove the oven racks which will then allow you to remove the oven panel on the bottom of the oven, once removed you'll see the burners and gain access to the ignitor attached to the burner tube...this will provide plenty of room. Let me know if any of this is not clear and I'll try and guide you through it. Regards, Macmarkus :)
12/5/2010 9:55:36 PM • Viking... • Answered on Dec 05, 2010
Viking VGSC306-4B Gas Kitchen Range Logo
Popular Tags
101 questions posted
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Kitchen Ranges
Most Popular Question
viking vgcc
  • Kitchen Ranges
