20 Most Recent
ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard Questions & Answers
Blue screen
Blue screens on a system with an activated copy of Windows are usually the result of hardware changes. I would take out or unplug everything except the boot drive. If it boots OK now, put things back in one at a time and reboot. I know it is time consuming, but if you do 2 or more at a time you don't know which one is causing the problem. I would take pictures of the insides the way they are now so there won;t be any confusion. Pictures are easy to delete, but hard to create if you don't have one of the connection you are unsure of two or three days from now.
11/2/2017 11:59:13 PM •
ASUS P5Q3...
Answered
on Nov 02, 2017
Hi I'm trying to use
you might have to open up
your network connections click start control panel network connections this may
vary depending on your operating system look for local area connection if you
see a red x or a yellow exclamation or question mark you will need to update or
install the driver or it could be firewalled
make
sure your modem/routers settings are correct ie:password user name,firewall
settings to allow your internet to connect to your phonehope this helps
11/7/2011 11:35:42 PM •
ASUS P5Q3...
Answered
on Nov 07, 2011
My problem is it doesn't
are the ram modules of the same type/brand
you might have a faulty ram module or a dirty or faulty socket try alternating the modules to see if you get the same result
if only using the one module keep it closest the CPU central processing unit
hope this helps
9/16/2011 10:29:45 PM •
ASUS P5Q3...
Answered
on Sep 16, 2011
I dont know settings for
That Motherboard have a PCI-Express x16 so the 6970 will fit without problem, these are powerful cards so you should have a good PSU (powersupply)
5/3/2011 4:35:03 PM •
ASUS P5Q3...
Answered
on May 03, 2011
ASUS P5Q3 with Xeon CPU
Yes, it will work. However it depends on which one you buy. Here's one that will work with that particular motherboard.
First, visit
this website. Now search for, "Xeon" (Without the quotes, though). Click the second result on the list, which should be the, "Intel Xeon E3110 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E3110 - Retail." That processor is a 45NM LGA-775 processor, which Asus claims that motherboard can support 45NM LGA-775 processor.
Let me know if I can assist you further, or if I need to explain anything in more detail. If this solves your question, please rate the solution.
3/23/2009 5:58:24 PM •
ASUS P5Q3...
Answered
on Mar 23, 2009
Loud ring while trying to boot for first time with Asus P5Q3
Hi im josh in cebu phils. may i help you. i got the same problem last week when i bought intel board. the same problem you have a long loud beep in the first boot. it is a video card problem.if you are using video card having 128 mb or below it will beep and may damage the motherboard. but when it is higher 128 like 256 or 512 mb it is good. i solved this problem of mine. i hope the same you too. Good luck
2/16/2009 10:30:54 AM •
ASUS P5Q3...
Answered
on Feb 16, 2009
Computer won't shut down.
Dear Catobion,
its a OS related problem, please call some technical guy ,which can reload the Operating system again in your pc, and i'm sure it will be work fine and faster.
Be Happy always
Scorpion
9/17/2008 4:09:35 AM •
ASUS P5Q3...
Answered
on Sep 17, 2008
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
