20 Most Recent General Electric WHRE5550H Top Load Washer Questions & Answers
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out.Here is the part to order.
You may also check this by removing the front and run a load of wash and watch the motor.
Please post back your finding to me.
General Electric... | Answered on Nov 06, 2013
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out. Here is the part to order.
Please post back your findings.
General Electric... | Answered on Nov 02, 2012
check the pump or drain pipe,these are the usual suspects
General Electric... | Answered on Nov 04, 2010
The pump will actually withstand the freezing, but to play it safe, just lay the drain hose down flat on the floor and allow the water to run out.
General Electric... | Answered on Aug 21, 2010
hello it is a simple repair , you either need to tighten the hose connection or replace the hose , you can buy them from bunnings store, if the hose is old better replace it
General Electric... | Answered on Jul 23, 2010
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
General Electric... | Answered on Nov 26, 2009
check voltage from switch to power board if ok bad display
General Washing... | Answered on Oct 24, 2020
I have super general washing machine model is sgw 620 this machine coming error E5
General Washing... | Answered on Jun 18, 2020
i don't know. i repaired same condition on different washer. it was the lid safety switch/pin contact. i tested
by pushing pencil in hole where safety pin goes.
DO NOT USE MACHINE WITHOUT WORKING LID CLOSED SAFETY LOCK. you could break an arm / hand.
i slid top off washing machine and moved lid switch back so ' lid pin ' would contact safety switch. if this is the cause, you may need to replace this low cost switch.
General Washing... | Answered on Jan 07, 2020
e3 mean to much water in washer,check inlet valve, are call a techicain to solve your problem
General Washing... | Answered on Jun 24, 2019
you can google you super general swg 1201 E01 error for instructions to trouble shoot. or try you tube.
General Washing... | Answered on May 04, 2019
The drain on the wall is called a Stand Pipe. It is designed to be higher than the washing machine so that you do not flood the building every time you do a load of wash. The Machine has a built-in pump to pump the water out of the machine when needed.
You will need to attach a washing machine drain hose to the machine. You should be able to find one at Lowes or Home Depot. https://www.lowes.com/pd/bosch-drain-hose-extension-kit-gray/1000024537?cm_mmc=shp-_-c-_-prd-_-app-_-google-_-pla-_-186-_-sosaccessories-_-1000024537-_-0&kpid&k_clickID=go_625713068_34614756550_111134534590_pla-261169297148_c_9027729&gclid=EAIaIQobChMIwc_2u8_-4AIV9x6tBh1fSA3fEAQYAyABEgJjjPD_BwE
General Washing... | Answered on Mar 13, 2019
Run the machine empty to see if you can clear some of the soap residue, E-4 is "suds lock" error and is usually due to using too much detergent.
General Washing... | Answered on Oct 03, 2018
when you let people know what type of machine it is then maybe we could help but go to the manufactures and download the user manual and check in the trouble shooting guide eric
General Washing... | Answered on Jan 02, 2018
hi
if you are familiar on how to use an electric multimeter
this is what you do access to the motor which does the washing / spinning find the cable that are attached to the motor remove cables screw them on to a separated connecting block now you select a program ( awash ) with no laundry start the program then set you meter to volts hold the meter prongs on the cable that you have already put into the block hold firm the prongs in each wire you then should get voltage ( hold for 5/8 minutes if the voltage do not get interrupted there is nothing wrong with the control board but the motor is faulty and vice versa
General Electric WHRE5550H Top Load Washer Logo
20 questions posted
Top General Washing Machines Experts
Michael Thomas
Michael Thomas
Richard C Cohen
Richard C Cohen
Are you a General Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Washing Machines
Most Popular Question
general electric washer model
  • Washing Machines
