20 Most Recent
Bosch WAS24460UC Front Load Washer Questions & Answers
Pump cap won't open?
Sounds like there is a large clog in the pump filter causing it do jam. You may have to work at it to remove it, or you may have to disassemble the washer and extract the clog manually by opening up the drain lines and pulling it back from the filter.
Code f43
Bosch 'F43' stands for 'motor fault'.
Motors- and belts, which are sensible to change at the same time- are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts, normally 2, should be loosened and the belt removed then remove the bolts completely
With the motor it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished. Refurbishing includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit firmly on the commutator but straddle it- the centre is often more worn than the outer part.
Unfortunately motors are not cheap- the motor for our 18+ yearold Bosch cost GBP250 but it will probably outlive us!
Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Our WAS24460UC stopped draining and showed F18.
Hi, F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display..
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required.
From your explanation so far about the F18 and the various repairs that has been carried out on the washer which includes replacing the pump and replacing the hose attached to the pump which ought to solve the problem instantly, but has not then i think you should under the warrantly clause ask for a replacement without further delay because repair is not suppose to take as long as this under a normal circumstance and am not sure they are approaching the problem in the right manner because this is a factory fault problem that requires total replacement..
To make matters worse, even the repair man feels replacing the pressure switch will still not solve the problem.
Brand new, just installed Bosch WAS34460 washer
Are you using HE detergent? Are you using the correct amount specified? You have a year warranty friend. Call Bosch directly. They do care about their customers. Do not go through Lxxxs or who you purchased the unit from. Other than some minor issues, Bosch wants to take care of their customers. One other thing. My biggest issue with installers is, they don't know how to install. They have their CDLS, and that is all. No training. Did they remove shipping bolts? Tub rubbing on front door seal could be burnt rubber smell. Bosch people on the whole, are good people. Good luck. Numbers are in your Manual. Check installation manual also. Good luck.
Washer is on spin cycles but not pumping and
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
