20 Most Recent General Electric WSXH208H Front Load Washer Questions & Answers
You can download GE owner's manuals here.
You can GE order parts and accessories here.
General Electric... | Answered on Jan 01, 2018
Go to kenmores site and download the manual
General Electric... | Answered on Jun 18, 2014
Remove the top panel, then remove the console to access the timer.
General Electric... | Answered on Dec 04, 2012
there is a tension wheel that keep tub in alignment, sounds like it needs to be replaced
General Electric... | Answered on May 08, 2010
check the belt in the back.
General Electric... | Answered on Feb 05, 2010
it needs to be leveled. most units are self leveling meaning they sit evenly. if yours in on uneven ground make sure you get it onto a flatter spot. should help.
General Electric... | Answered on Sep 16, 2009
When in spin programme drum rocks and bangs. Quite extreme.
General Electric... | Answered on May 31, 2009
The washer is new and under warranty so I have asked for warranty service.
General Electric... | Answered on May 24, 2009
check voltage from switch to power board if ok bad display
General Washing... | Answered on Oct 24, 2020
I have super general washing machine model is sgw 620 this machine coming error E5
General Washing... | Answered on Jun 18, 2020
i don't know. i repaired same condition on different washer. it was the lid safety switch/pin contact. i tested
by pushing pencil in hole where safety pin goes.
DO NOT USE MACHINE WITHOUT WORKING LID CLOSED SAFETY LOCK. you could break an arm / hand.
i slid top off washing machine and moved lid switch back so ' lid pin ' would contact safety switch. if this is the cause, you may need to replace this low cost switch.
General Washing... | Answered on Jan 07, 2020
e3 mean to much water in washer,check inlet valve, are call a techicain to solve your problem
General Washing... | Answered on Jun 24, 2019
you can google you super general swg 1201 E01 error for instructions to trouble shoot. or try you tube.
General Washing... | Answered on May 04, 2019
The drain on the wall is called a Stand Pipe. It is designed to be higher than the washing machine so that you do not flood the building every time you do a load of wash. The Machine has a built-in pump to pump the water out of the machine when needed.
You will need to attach a washing machine drain hose to the machine. You should be able to find one at Lowes or Home Depot. https://www.lowes.com/pd/bosch-drain-hose-extension-kit-gray/1000024537?cm_mmc=shp-_-c-_-prd-_-app-_-google-_-pla-_-186-_-sosaccessories-_-1000024537-_-0&kpid&k_clickID=go_625713068_34614756550_111134534590_pla-261169297148_c_9027729&gclid=EAIaIQobChMIwc_2u8_-4AIV9x6tBh1fSA3fEAQYAyABEgJjjPD_BwE
General Washing... | Answered on Mar 13, 2019
General Electric WSXH208H Front Load Washer Logo
19 questions posted
Top General Washing Machines Experts
Michael Thomas
Michael Thomas
Richard C Cohen
Richard C Cohen
Are you a General Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Washing Machines
Most Popular Question
drum unbalanced
  • Washing Machines
