20 Most Recent
Cuisinart PSC-650 6.5-Quart Slow Cooker Questions & Answers
How can I fix E1 code? on the digital display?
Factory reset the slow cooker. To do this, and this is only an educated guess as no information is available in the user manual for this device, is hold the clear button if there is one while powering it off, or press the + and - buttons simultaneously and hold for several seconds to clear the screen.
6/8/2015 12:29:36 AM •
Cuisinart...
Answered
on Jun 08, 2015
Rice cooker retractable cord burned.
If the mechanical part is still good then any handy person can replace the cord with any purchased cord but to do so safely it would be best to have someone with electrical training to do so
11/24/2013 1:06:48 AM •
Cuisinart...
Answered
on Nov 24, 2013
Cuisinart slow cooker shuts off before timer is done. It is older, doesn't have a weight sensor so is there a way to rest?
If your Cuisinart slow cooker is shutting off before the timer is done, it is possible that the slow cooker is overheating or experiencing an electrical issue. Here are a few things you can try to troubleshoot the issue:
- Check the slow cooker for any visible signs of damage, such as a cracked or broken heating element or loose wiring. If you see any damage, stop using the slow cooker and unplug it until it can be repaired by a qualified technician.
- Make sure the slow cooker is placed on a flat, stable surface and is not being overloaded. Overloading the slow cooker or placing it on an unstable surface can cause it to malfunction.
- Check the power cord and plug for any visible signs of damage, such as fraying or exposed wires. If the cord or plug is damaged, stop using the slow cooker and unplug it until it can be repaired by a qualified technician.
- If the slow cooker is clean and undamaged and is placed on a flat, stable surface, try unplugging it and then plugging it back in to see if the issue is resolved.
If these troubleshooting steps do not resolve the issue, it is possible that the slow cooker is experiencing a malfunction that requires repair by a qualified technician. I recommend contacting Cuisinart or a local appliance repair service for further assistance
