20 Most Recent Jack Lalanne Health Master 100 Blender 8-Speed Blender Questions & Answers
First determine..if it is indeed the motor that is fried. Do this by not using the caraffe. Plug in the motor and run it by itself. If it runs fine without smoking again..It is the caraffe that is defective.
If its the motor you are out of luck completely. Jack Lalanne is out of business.
If it is the caraffe..which I suspect it is not...oil the rim of the bearing that is on the outside of your caraffe ..it surrounds the knurled part that is inserted into the blender...even if you are able to get the motor repaired..get in the habit of oiling the caraffe bearing after each time you use it. If you dont it will fail within months to a year of use
Lalanne had they made in China..and using unsealed bearinga that rust out and the contents of the blender come out!! So I discovere dthat oiling that part each time after use..keeps my blender running smoothly.
You might want to take yoru motor to a small appliance repairman..he might find something simple happened.. like a loose wire connection inside! If he does...you have a simple solution and a motor that works!
Remember to oil the bearing a couple drops each time after use...and if yoru caraffe ever fails you can buy a new one..( Oil that one too!) at Cooking Toys..you can google for the address
[email protected]
Jack Lalanne... | Answered on Jul 16, 2014
Hi nathanbenson,
The product has been discontinued and you might find it hard loking for a replacement part online. However, if you will call the manufacturer Tristar directly they can help you with this. You may call them at 973 575 5400 ext129.
Hope this helps.
Thank you for using FixYa.
Jack Lalanne... | Answered on Jun 20, 2011
I have been thru the fire about this! I sent my Healthmaster in recd another and it failed also. Almost always..it is the bearing that fails in the caraffe that supports the blade. The bearings that Jack Lalanne had installed in China..were not sealed...so they would allow water to enter corrode and eventually all of your blenders contents would come out thru the bottom! Or another thing that can happen is your blade will freeze up due to corrosion....and become immovable.
Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..lalannes distributor..BECAUSE they authorized me sending my belnder back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up teh dough
So I doubt you can receive any money.
But this is what you CAN do!
1) If your motor functions well..you can buy a new carafe for 45 dollars or so from Cooking toys ( google cooking toys and it should come up)
2) OR if your cheap like me...and your blade doesnt rotate easily due to corrosion and your caraffe isnt leaking much...put a couple drops of oil on the outter rim of the bearing ( That would be located directly on the bottom of the outside of the caraffe..it surrounds the knurled metal part that is inserted in the motor for blending.
My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have ben able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
3) If you buy a new caraffe form cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST INDEFINITELY>>>BUT TIME WILL TELL!
Jack Lalanne... | Answered on Apr 12, 2011
You did not specify where the leak is coming from, so I can only guess and my guess is the base. Assemble gasket first, then blade plate and then base retainer. You can tighten the base tighter while the unit is on the motor base. the motor base will let you get it slightly tighter.
Jack Lalanne... | Answered on Dec 12, 2010
I wish I could tell you a definite solution. Have you tried calling 973-575-5400 (ext 129)? I realize it isn't toll-free. According to several web sites, the manufacturer has discontinued the product, but they should definitely still be supporting the motor warranty.
Mine is eating the bearing in the bottom of the pitcher. That seems to be everyone's most frequent problem although mine hasn't actually started to leak yet. The motor is just fine. I suspect Jack Lalanne started getting complaints about the pitcher bearing and dropped his support for the product because of that.
Jack Lalanne... | Answered on Jul 08, 2010
Jack Lalanne Health Master 100 Blender 8-Speed Blender Logo
38 questions posted
Top Jack Lalanne Blenders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Jack Lalanne Blender Expert? Answer questions, earn points and help others
View Most Popular
  • Jack Lalanne Blenders
Most Popular Question
need two liter
  • Blenders
