20 Most Recent
PetSafe Pet Safe In-Ground Stubborn Dog Fence Questions & Answers
How to set the collar of a Petafe in ground fence.
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
Is CBD Pet Products Safe for My Pet?
As a caring owner of a pet, it is right that you are concerned about whether
CBD Pet Products will be safe for your furry family member. The thing to remember here is that CBD in its pure state can be tolerated well by animals and are safe. This has been stated by the World Health Organization's 2017 report. However, you should remember that the market for CBD Products is not regulated. So, there are chances that the CBD gummies and other products can contain ingredients that are listed on the label including THC, which can be toxic to pets. All you have to do to ensure the safety of your pet is to get the product from a trustworthy source.
How to get rid of racoons
to get racoons rid follow these steps
- Cover and secure your trash cans so raccoons cannot access the contents.
- Remove any possible food sources like cat or dog food, compost piles, and trash.
- Treat your lawn to remove grubs.
- Block access to hiding places like under a deck or entrances to the crawl space and attic.
Animals symbolic meanings
Cats symbolise elegance, curiosity, courage and adaptability. Dog - Typifies loyalty, kinship, bravery, perseverance, and happiness and also conveys protection and reliability. Penguin - These aquatic birds symbolise devotion, loyalty, unity, and lasting love.
What is fever dog is
A dog's normal body temperature ranges from 101° to 102.5° Fahrenheit, which is significantly higher than humans whose body temperature ranges from 97.6° to 99.6° F. A temperature of more than 103° F is considered a dog fever. When temperatures reach 106° F, serious and fatal complications can occur.
What can i give my dog for diarrhea whilst nursing pups
Fast your dog for 24 hours. Only water is permitted. After the 24 hour fast, begin feeding a combination of boiled white meat chicken (with all the skin and fat removed and the water poured off) and boiled long grain white rice. Boiled ground beef with fat removed and water poured off is also a good alternative.
Why is my Staffordshire scratching all the time and chewing at her feet
Could be a food allergy; don't buy cheap treats or food from supermarkets, they have colouring and toxic chemicals in them. Go to a propper independant pet store.
There is also an issue with the floor cleaning products, always use a non chemical cleanser like Savlon floor cleaner. No harsh chemicals in it.
Check for grass mites.
